주요 콘텐츠로 건너뛰기
2003-2007 Honda Accord Cabin Air Filter Replacement
필요한 것
  1. 2003-2007 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/2 2003-2007 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/2
    • Open the passenger side door and locate the glove box. Open and empty the glove box.
  2. 2003-2007 Honda Accord Cabin Air Filter Replacement: 2 단계, 이미지 1/1
    • Identify the glove box damper assy latch on the right side of the glove box. Using moderate force, press against the latch with your thumb until it pops out of place.
  3. 2003-2007 Honda Accord Cabin Air Filter Replacement: 3 단계, 이미지 1/1
    • The glove box is held in place by tabs on both sides. Push inward on both sides of the box to allow the glove box to drop clear the tabs and drop downward slowly.
  4. 2003-2007 Honda Accord Cabin Air Filter Replacement: 4 단계, 이미지 1/3 2003-2007 Honda Accord Cabin Air Filter Replacement: 4 단계, 이미지 2/3 2003-2007 Honda Accord Cabin Air Filter Replacement: 4 단계, 이미지 3/3
    • Now that the cabin air filter housing is visible locate the locking tabs on the left and right edges.
    • Push the tabs inward and gently shake the housing free while pulling straight out.
    • When reassembling, push the filter tray in gently until both locking tabs click into position. The filter must be inserted into the tray fully for the tray to fit back in.
  5. 2003-2007 Honda Accord Cabin Air Filter Replacement: 5 단계, 이미지 1/1
    • Push the air filter out of the plastic housing from the bottom and discard.
  6. 2003-2007 Honda Accord Cabin Air Filter Replacement: 6 단계, 이미지 1/2 2003-2007 Honda Accord Cabin Air Filter Replacement: 6 단계, 이미지 2/2
    • Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
    • Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
    • Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray to prevent any particulates passing around the filter.
결론
다른 21명이 해당 안내서를 완성하였습니다.
Shaun MacDonald
회원 가입일: 10/03/12
2,438 평판
안내서 8개 작성하였습니다
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012 회원
CPSU-REGAN-F12S24G27
4 회원들
안내서 21개 작성하였습니다
댓글 한 개
Good easy to understand directions and removal of cabin air filter . Thank You
raysanchez120 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 30
30일 전: 146
전체 시간: 29,858
