소개
It is suggested that the cabin air filter be replaced every 15,000 miles.
도구
지정된 도구가 없습니다.
Open the passenger side door and locate the glove box. Open and empty the glove box.
Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray.
다른 17명이 해당 안내서를 완성하였습니다.
댓글 3개
Is it that hard to say i don,t know instead of line of bs. Thank you shaun, saved me time an aggrevation. Your true car guy bro.
What are you taking about? What part of this guide is BS?
Good easy to understand directions and removal of cabin air filter . Thank You
