이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
It is suggested that the cabin air filter be replaced every 15,000 miles.
필요한 것
Open the passenger side door and locate the glove box. Open and empty the glove box.
Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray.
다른 21명이 해당 안내서를 완성하였습니다.
댓글 한 개
Good easy to understand directions and removal of cabin air filter . Thank You
