주요 콘텐츠로 건너뛰기
2003-2007 Honda Accord Interior Door Handle Replacement
필요한 것
  1. 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: 1 단계, 이미지 1/3 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: 1 단계, 이미지 2/3 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: 1 단계, 이미지 3/3
    • Open the appropriate side door of your vehicle that requires a door handle replacement.
    • Locate the tab on the panel behind the door handle.
    • Use a flat-head screwdriver (1 x 3 mm) to move the tab to the right and slightly pull the panel out.
  2. 2003-2007 Honda Accord Interior Door Handle Replacement: 2 단계, 이미지 1/3 2003-2007 Honda Accord Interior Door Handle Replacement: 2 단계, 이미지 2/3 2003-2007 Honda Accord Interior Door Handle Replacement: 2 단계, 이미지 3/3
    • Locate two (2) Phillips head screws behind the door handle.
    • Remove the two Phillips head screws (1.6 x 1.3 x 10.16 mm) using a Phillips head screwdriver (1 x 3 mm).
  3. 2003-2007 Honda Accord Interior Door Handle Replacement: 3 단계, 이미지 1/3 2003-2007 Honda Accord Interior Door Handle Replacement: 3 단계, 이미지 2/3 2003-2007 Honda Accord Interior Door Handle Replacement: 3 단계, 이미지 3/3
    • The first image shows the approximate location of 3 tabs behind the door handle assembly. Knowing the location of tabs is useful when attempting to release assembly.
    • Using your left hand, pull the assembly to the left to reveal the tab on the right. While pulling on the assembly, use a flat-head screwdriver (1 x 3 mm) to press the tab inward to release.
    • Once the tab on the right is released, a slight pull of assembly will release it from the door.
  4. 2003-2007 Honda Accord Interior Door Handle Replacement: 4 단계, 이미지 1/3 2003-2007 Honda Accord Interior Door Handle Replacement: 4 단계, 이미지 2/3 2003-2007 Honda Accord Interior Door Handle Replacement: 4 단계, 이미지 3/3
    • Rotate the door handle assembly for ease of access to clips
    • Locate the first clip holding the door cable.
    • Rotate the clip clockwise to unlock the cable.
    • Once unlocked, pull the cable end from the holder.
  5. 2003-2007 Honda Accord Interior Door Handle Replacement: 5 단계, 이미지 1/2 2003-2007 Honda Accord Interior Door Handle Replacement: 5 단계, 이미지 2/2
    • Locate the second clip holding the door cable.
    • Using a flat-head screwdriver (1 x 3 mm), release the clip.
    • Once the cable is released, the assembly is free to remove.
결론
To install your new door handle assembly, follow these instructions in reverse order.
Additional tips: For step 5, the clip will be pushed back into the clip holder. For step 4, replace the cable and rotate the clip clockwise.
Erik amundsen
회원 가입일: 02/22/24
121 평판
안내서 1개 작성함
University of Arizona, Team 3-12, Cools Stephens Spring 2024 University of Arizona, Team 3-12, Cools Stephens Spring 2024 회원
ARIZONA-COOLS STEPHENS-S24S3G12
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 78
