소개
If your 2003-2007 Honda Accord key fob operates intermittently, the battery may need to be replaced. Use this guide to replace the battery in a 2003-2007 Honda Accord keyless fob remote.
Alternatively, follow the video tutorial from YouTuber NutzAboutBolts to complete the battery replacement.
도구
부품
동영상 개요
Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
