주요 콘텐츠로 건너뛰기
2003-2007 Honda Accord Key Fob Battery Replacement
필요한 것
동영상 개요
  1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 1/3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 2/3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
  2. 2003-2007 Honda Accord Key Fob Battery Replacement: 2 단계, 이미지 1/3 2003-2007 Honda Accord Key Fob Battery Replacement: 2 단계, 이미지 2/3 2003-2007 Honda Accord Key Fob Battery Replacement: 2 단계, 이미지 3/3
    • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
    • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
    • Remove the bottom portion of the key fob.
  3. 2003-2007 Honda Accord Key Fob Battery Replacement: 3 단계, 이미지 1/3 2003-2007 Honda Accord Key Fob Battery Replacement: 3 단계, 이미지 2/3 2003-2007 Honda Accord Key Fob Battery Replacement: 3 단계, 이미지 3/3
    • Remove the inner portion of the key fob.
  4. 2003-2007 Honda Accord Key Fob Battery Replacement: 4 단계, 이미지 1/3 2003-2007 Honda Accord Key Fob Battery Replacement: 4 단계, 이미지 2/3 2003-2007 Honda Accord Key Fob Battery Replacement: 4 단계, 이미지 3/3
    • Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
    • Separate the two sides of the fob's inner portion.
  5. 2003-2007 Honda Accord Key Fob Battery Replacement: 5 단계, 이미지 1/3 2003-2007 Honda Accord Key Fob Battery Replacement: 5 단계, 이미지 2/3 2003-2007 Honda Accord Key Fob Battery Replacement: 5 단계, 이미지 3/3
    • Use a flathead screwdriver to pry up the circular battery.
    • Remove the key fob's battery.
    This is nice except for the fact that it shows the battery positioned upside down.
    essin - 답글
결론
다른 3명이 해당 안내서를 완성하였습니다.
eCuration
회원 가입일: 05/19/17
376,693 평판
안내서 234개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
Debra Burrell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 34
7일 전: 250
30일 전: 1,413
전체 시간: 141,484
