주요 콘텐츠로 건너뛰기
2003-2007 Honda Accord Side Mirror Replacement
필요한 것
  1. 2003-2007 Honda Accord Side Mirror Replacement, Side Mirror: 1 단계, 이미지 1/2 2003-2007 Honda Accord Side Mirror Replacement, Side Mirror: 1 단계, 이미지 2/2
    • Remove the panel that is on the end of the car door above the the door handle.
    • The panel will be a bit hard to take off, but a couple of jolts, and the panel will come off fairly easy.
  2. 2003-2007 Honda Accord Side Mirror Replacement: 2 단계, 이미지 1/1
    • Press down on the middle button and then pull out the wire.
  3. 2003-2007 Honda Accord Side Mirror Replacement: 3 단계, 이미지 1/2 2003-2007 Honda Accord Side Mirror Replacement: 3 단계, 이미지 2/2
    • Remove the three 8mm bolts with the socket wrench and 8mm socket header.
  4. 2003-2007 Honda Accord Side Mirror Replacement: 4 단계, 이미지 1/1
    • Push the plastic bit towards car door to remove the side mirror.
    • Remove the side mirror.
결론
Jason Aguilar
회원 가입일: 10/23/20
109 평판
안내서 1개 작성함
CSU Los Angeles, Team S12-G21, Harris Fall 2020 CSU Los Angeles, Team S12-G21, Harris Fall 2020 회원
CSULA-HARRIS-F20S12G21
1 회원
안내서 1개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 179
전체 시간: 1,989
