주요 콘텐츠로 건너뛰기
2003 Chevrolet Cavalier Engine Air Filter Replacement
필요한 것
  1. 2003 Chevrolet Cavalier Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 1/2 2003 Chevrolet Cavalier Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 2/2
    • Pull the hood release lever.
    • This lever is located inside the cabin of the car to the left of the pedals.
  2. 2003 Chevrolet Cavalier Engine Air Filter Replacement: 2 단계, 이미지 1/2 2003 Chevrolet Cavalier Engine Air Filter Replacement: 2 단계, 이미지 2/2
    • Pull up on the hood slightly and lift the safety latch.
    • The hood will not open unless the safety latch has been lifted.
  3. 2003 Chevrolet Cavalier Engine Air Filter Replacement: 3 단계, 이미지 1/2 2003 Chevrolet Cavalier Engine Air Filter Replacement: 3 단계, 이미지 2/2
    • Open the hood and hold it with one hand.
    • Grab the prop rod in the other hand.
    • Insert the prop rod into one of the slots in the hood to secure it in place.
    • Make sure the prop rod is secure in the slot otherwise the hood may fall.
  4. 2003 Chevrolet Cavalier Engine Air Filter Replacement: 4 단계, 이미지 1/3 2003 Chevrolet Cavalier Engine Air Filter Replacement: 4 단계, 이미지 2/3 2003 Chevrolet Cavalier Engine Air Filter Replacement: 4 단계, 이미지 3/3
    • Unclip the wiring harness from the retaining clamps with a flathead screwdriver.
    • Pull the wiring harness out of the clamps.
  5. 2003 Chevrolet Cavalier Engine Air Filter Replacement: 5 단계, 이미지 1/2 2003 Chevrolet Cavalier Engine Air Filter Replacement: 5 단계, 이미지 2/2
    • Unscrew the four cover-mounting screws holding the air filter cover on.
    • The screws do not come out of the filter housing.
  6. 2003 Chevrolet Cavalier Engine Air Filter Replacement: 6 단계, 이미지 1/1
    • Separate the housing halves to access the air filter element.
  7. 2003 Chevrolet Cavalier Engine Air Filter Replacement: 7 단계, 이미지 1/3 2003 Chevrolet Cavalier Engine Air Filter Replacement: 7 단계, 이미지 2/3 2003 Chevrolet Cavalier Engine Air Filter Replacement: 7 단계, 이미지 3/3
    • Remove the old air filter.
    • Place the new filter in the housing.
    • The new air filter will sit comfortably in place without wobbling.
결론
Dawson Stroik
회원 가입일: 10/05/23
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 95
