소개
Driving in the dark or in adverse weather with burnt out headlights is illegal and dangerous. Although headlight bulbs are relatively affordable, auto shops often charge additional installation fees. This guide will explain how to replace a headlight bulb on your 2003 Ford Taurus, so you can drive safely and avoid unnecessary costs.
필요한 것
Open the hood of the car by pulling the hood release lever located inside the car. The lever can be found on the driver’s side, down and to the left of the emergency brake release. It should contain a symbol of a car with a raised hood.
After pulling the lever, the hood should pop up slightly. To raise it fully, first release the safety latch, located centrally on the front of the hood, by pushing it all the way to the left.
Pull the hood all the way up.
Firmly grip the bulb with one hand and the bulb holder with the other hand. Pull the two components apart to remove the old bulb, keeping the retainer ring on the side of the bulb holder.
Insert the new bulb by aligning it with the connections on the holder and press the two pieces firmly together until they “click.”
다른 한 분이 해당 안내서를 완성하였습니다.
