주요 콘텐츠로 건너뛰기
2003 Toyota Solara Tail Light Replacement
필요한 것
  1. 2003 Toyota Solara Tail Light Replacement, Tail Light: 1 단계, 이미지 1/1
    • Park the vehicle and turn off the engine.
    • Step on the brake pedal to confirm whether or not the tail light is responsive.
  2. 2003 Toyota Solara Tail Light Replacement: 2 단계, 이미지 1/3 2003 Toyota Solara Tail Light Replacement: 2 단계, 이미지 2/3 2003 Toyota Solara Tail Light Replacement: 2 단계, 이미지 3/3
    • Reach underneath the steering wheel. Then, place your hand to the left to remove the fuse box cover.
  3. 2003 Toyota Solara Tail Light Replacement: 3 단계, 이미지 1/2 2003 Toyota Solara Tail Light Replacement: 3 단계, 이미지 2/2
    • Reference the fuse box guide on the back of the cover.
    • Locate the fuse number that corresponds to the tail light (2nd column, last row).
    • Replace the tail lamp if the fuse is still functional.
  4. 2003 Toyota Solara Tail Light Replacement: 4 단계, 이미지 1/2 2003 Toyota Solara Tail Light Replacement: 4 단계, 이미지 2/2
    • Open the vehicle's trunk.
    • Unscrew the plastic fastenings located inside the trunk.
    • Detach the panel covering the tail light.
  5. 2003 Toyota Solara Tail Light Replacement: 5 단계, 이미지 1/3 2003 Toyota Solara Tail Light Replacement: 5 단계, 이미지 2/3 2003 Toyota Solara Tail Light Replacement: 5 단계, 이미지 3/3
    • Untwist the wired socket to expose the lamp bulb.
    • Check the bulb for discoloration (if it is clouded, replace the bulb).
  6. 2003 Toyota Solara Tail Light Replacement: 6 단계, 이미지 1/2 2003 Toyota Solara Tail Light Replacement: 6 단계, 이미지 2/2
    • Insert the new bulb into the socket.
    • Push until there is an audible "click".
결론
To reassemble the tail lamp, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Melissa Spinali
회원 가입일: 04/28/17
107 평판
안내서 1개 작성함
UC Davis, Team S2-G2, Cole Spring 2017 UC Davis, Team S2-G2, Cole Spring 2017 회원
UCD-COLE-S17S2G2
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 69
전체 시간: 2,778
