주요 콘텐츠로 건너뛰기
2004-2015 Nissan Frontier Tail Light Replacement
필요한 것
  1. 2004-2015 Nissan Frontier Tail Light Replacement, Tail Light Bulb: 1 단계, 이미지 1/2 2004-2015 Nissan Frontier Tail Light Replacement, Tail Light Bulb: 1 단계, 이미지 2/2
    • Open the tailgate by lifting the center handle.
  2. 2004-2015 Nissan Frontier Tail Light Replacement: 2 단계, 이미지 1/3 2004-2015 Nissan Frontier Tail Light Replacement: 2 단계, 이미지 2/3 2004-2015 Nissan Frontier Tail Light Replacement: 2 단계, 이미지 3/3
    • Unscrew the two Phillips #1 screws.
  3. 2004-2015 Nissan Frontier Tail Light Replacement: 3 단계, 이미지 1/2 2004-2015 Nissan Frontier Tail Light Replacement: 3 단계, 이미지 2/2
    • Pull the tail light assembly out of its place within the frame of the vehicle.
  4. 2004-2015 Nissan Frontier Tail Light Replacement: 4 단계, 이미지 1/3 2004-2015 Nissan Frontier Tail Light Replacement: 4 단계, 이미지 2/3 2004-2015 Nissan Frontier Tail Light Replacement: 4 단계, 이미지 3/3
    • Twist the bulb within its socket counter-clockwise, then remove it from the inner assembly.
    • Remove the bulb by pulling directly out of the socket.
  5. 2004-2015 Nissan Frontier Tail Light Replacement: 5 단계, 이미지 1/3 2004-2015 Nissan Frontier Tail Light Replacement: 5 단계, 이미지 2/3 2004-2015 Nissan Frontier Tail Light Replacement: 5 단계, 이미지 3/3
    • Gently place your replacement bulb into the socket.
    • Insert the socket back into the tail light assembly, then twist clockwise until secure.
  6. 2004-2015 Nissan Frontier Tail Light Replacement: 6 단계, 이미지 1/3 2004-2015 Nissan Frontier Tail Light Replacement: 6 단계, 이미지 2/3 2004-2015 Nissan Frontier Tail Light Replacement: 6 단계, 이미지 3/3
    • Gently place the tail light assembly back into its original position.
    • Screw back in the Phillips #1 screws.
  7. 2004-2015 Nissan Frontier Tail Light Replacement: 7 단계, 이미지 1/2 2004-2015 Nissan Frontier Tail Light Replacement: 7 단계, 이미지 2/2
    • Close the tail gate.
    • Turn on your truck to ensure that the lights are in working condition.
결론
Alejandro Jimenez
회원 가입일: 10/24/23
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 8-4, Ribeiro Fall 2023 CSU Los Angeles, Team 8-4, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S8G4
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 60
전체 시간: 558
