주요 콘텐츠로 건너뛰기
2004-2008 Ford F150 Tail Light Bulb Replacement
필요한 것
  1. 2004-2008 Ford F150 Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 1/1
    • Park the vehicle on a level surface.
    • Turn the vehicle off.
    • If the vehicle is not turned off, there is a risk of electrocution upon removal of the tail light.
  2. 2004-2008 Ford F150 Tail Light Bulb Replacement: 2 단계, 이미지 1/1
    • Lower the tailgate.
  3. 2004-2008 Ford F150 Tail Light Bulb Replacement: 3 단계, 이미지 1/3 2004-2008 Ford F150 Tail Light Bulb Replacement: 3 단계, 이미지 2/3 2004-2008 Ford F150 Tail Light Bulb Replacement: 3 단계, 이미지 3/3
    • Use the 8mm socket wrench to remove both of the mounting bolts.
    • An 8mm crescent wrench can be used in place of the 8mm socket wrench.
  4. 2004-2008 Ford F150 Tail Light Bulb Replacement: 4 단계, 이미지 1/2 2004-2008 Ford F150 Tail Light Bulb Replacement: 4 단계, 이미지 2/2
    • Remove the tail light by pulling the tail light housing straight back, away from the vehicle.
    • If the tail light housing is too difficult to remove use a thin, stiff piece of plastic as a pry bar to aid in removing the tail light housing.
    • If a pry bar is used, take caution to not scratch the paint of the vehicle.
  5. 2004-2008 Ford F150 Tail Light Bulb Replacement: 5 단계, 이미지 1/1
    • Twist the upper socket counter clockwise.
    • Pull back to remove the socket from the tail light assembly.
  6. 2004-2008 Ford F150 Tail Light Bulb Replacement: 6 단계, 이미지 1/2 2004-2008 Ford F150 Tail Light Bulb Replacement: 6 단계, 이미지 2/2
    • Pull the bulb out of the socket.
    • When handling the replacement bulb, be careful to minimize contact with the bulb itself; as the oils from your hand can decrease the lifespan of the bulb.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Eric Carnes
회원 가입일: 06/20/18
274 평판
안내서 1개 작성함
Washington State, Team S1-G5, Hope Summer 2018 Washington State, Team S1-G5, Hope Summer 2018 회원
WSU-HOPE-SU18S1G5
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 23
30일 전: 82
전체 시간: 10,386
