주요 콘텐츠로 건너뛰기
2004-2008 Mazda RX-8 Air Filter Replacement
  1. 2004-2008 Mazda RX-8 Air Filter Replacement, Air Filter: 1 단계, 이미지 1/1
    • Begin by opening the hood of the vehicle and locating the air filter cover.
    • The air filter is located in the middle of the front of the vehicle covered by a large black rectangular cover.
  2. 2004-2008 Mazda RX-8 Air Filter Replacement: 2 단계, 이미지 1/3 2004-2008 Mazda RX-8 Air Filter Replacement: 2 단계, 이미지 2/3 2004-2008 Mazda RX-8 Air Filter Replacement: 2 단계, 이미지 3/3
    • Locate the two tabs on either side of the front of the air filter cover. Grab and pop open these two tabs.
    • Push the air filter cover open with your fingers. The air filter will now be visible and begin to pop up.
    • Once the air filter pops up, you can grab it with your hands and begin to remove it from the cover that is still being held open.
  3. 2004-2008 Mazda RX-8 Air Filter Replacement: 3 단계, 이미지 1/2 2004-2008 Mazda RX-8 Air Filter Replacement: 3 단계, 이미지 2/2
    • Gently pull the entire air filter out of the opened cover. This might take more than one set of hands in order to keep the cover open during removal.
    • The air filter is now fully removed and outside of the air filter cover. Obtain a new air filter to replace the old one.
  4. 2004-2008 Mazda RX-8 Air Filter Replacement: 4 단계, 이미지 1/3 2004-2008 Mazda RX-8 Air Filter Replacement: 4 단계, 이미지 2/3 2004-2008 Mazda RX-8 Air Filter Replacement: 4 단계, 이미지 3/3
    • Pry apart the cover of the air filter again to begin inserting your new air filter.
    • Gently push the new air filter back into the opened air filter cover the same way you removed it. The air filter will fall back into its resting position.
    • Once the new air filter has been fully inserted into the cover, close the cover and push the two tabs on the outside of the cover closed.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Laura Pritchard
회원 가입일: 04/20/15
199 평판
안내서 1개 작성함
Cal Poly, Team 8-4, Regan Spring 2015 Cal Poly, Team 8-4, Regan Spring 2015 회원
CPSU-REGAN-S15S8G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 22
전체 시간: 4,093
