주요 콘텐츠로 건너뛰기
2004-2008 Mazda RX-8 Battery Replacement
필요한 것
  1. 2004-2008 Mazda RX-8 Battery Replacement, Battery: 1 단계, 이미지 1/3 2004-2008 Mazda RX-8 Battery Replacement, Battery: 1 단계, 이미지 2/3 2004-2008 Mazda RX-8 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Find black tabs that lock Battery cover into place.
    • The tabs should snap off easily.
  2. 2004-2008 Mazda RX-8 Battery Replacement: 2 단계, 이미지 1/2 2004-2008 Mazda RX-8 Battery Replacement: 2 단계, 이미지 2/2
    • Use the 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
    • It is vital to disconnect the negative terminal before interacting with the battery. Make sure not to bridge the two terminals with your wrench or other tools.
    • Remove the terminals once nuts are completely loose.
  3. 2004-2008 Mazda RX-8 Battery Replacement: 3 단계, 이미지 1/1
    • Remove Battery terminals.
  4. 2004-2008 Mazda RX-8 Battery Replacement: 4 단계, 이미지 1/1
    • Using the 10mm Wrench remove gold nuts that hold the retention bar in place.
  5. 2004-2008 Mazda RX-8 Battery Replacement: 5 단계, 이미지 1/1
    • After removing the bar pull the dead battery out using the black straps.
결론
After replacing the device, follow these instructions in reverse order to secure a new battery in its place.
다른 2명이 해당 안내서를 완성하였습니다.
Gerrit Mouw
회원 가입일: 05/01/15
253 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-4, Regan Spring 2015 Cal Poly, Team 8-4, Regan Spring 2015 회원
CPSU-REGAN-S15S8G4
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 52
전체 시간: 15,795
