주요 콘텐츠로 건너뛰기
2004-2007 Chevrolet Malibu Headlight Replacement
필요한 것
  1. 2004-2007 Chevrolet Malibu Headlight Replacement, Removing Screws: 1 단계, 이미지 1개 중 1개
    • First pop the hood of the car and locate the headlight. They are towards the front of the car.
  2. 2004-2007 Chevrolet Malibu Headlight Replacement: 2 단계, 이미지 3개 중 1개 2004-2007 Chevrolet Malibu Headlight Replacement: 2 단계, 이미지 3개 중 2개 2004-2007 Chevrolet Malibu Headlight Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the 10 mm screws attaching the headlight to the car.
  3. 2004-2007 Chevrolet Malibu Headlight Replacement, Take out the headlight: 3 단계, 이미지 2개 중 1개 2004-2007 Chevrolet Malibu Headlight Replacement, Take out the headlight: 3 단계, 이미지 2개 중 2개
    • Remove the headlight so you can see all wiring going from the car and to the headlight.
  4. 2004-2007 Chevrolet Malibu Headlight Replacement, Safety Caps: 4 단계, 이미지 2개 중 1개 2004-2007 Chevrolet Malibu Headlight Replacement, Safety Caps: 4 단계, 이미지 2개 중 2개
    • Remove the safety caps to get a good a view of your bulb wiring.
  5. 2004-2007 Chevrolet Malibu Headlight Replacement, Remove the Bulb: 5 단계, 이미지 1개 중 1개
    • Turn the bulb counter clockwise then pull it out.
  6. 2004-2007 Chevrolet Malibu Headlight Replacement, Separate the bulb and pigtail: 6 단계, 이미지 2개 중 1개 2004-2007 Chevrolet Malibu Headlight Replacement, Separate the bulb and pigtail: 6 단계, 이미지 2개 중 2개
    • Pull back the clip that's holding the bulb (top half) and the pigtail (bottom half) together.
    • Pull apart the two, exposing the inside of the damaged pigtail.
  7. 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: 7 단계, 이미지 3개 중 1개 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: 7 단계, 이미지 3개 중 2개 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: 7 단계, 이미지 3개 중 3개
    • Now that you have separated the bulb and pigtail, detach the pigtail end from the car wires using wire cutters or scissors.
    • How To Cut With Wire Cutters
    • After cutting the wires, grab your new pigtail and pull back the rubber surrounding the wire. Pull back the rubber so there is enough wire to twist (connect) to the car wire.
  8. 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: 8 단계, 이미지 3개 중 1개 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: 8 단계, 이미지 3개 중 2개 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: 8 단계, 이미지 3개 중 3개
    • Once you've connected the pigtail back to the car be sure to wrap the wire in electrical tape.
    • Then grab your new bulb and attach it to the new pigtail by pushing it together until the clip has clicked.
    • Put the safety caps back on.
  9. 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: 9 단계, 이미지 3개 중 1개 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: 9 단계, 이미지 3개 중 2개 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: 9 단계, 이미지 3개 중 3개
    • Take your new bulb and place it back inside the headlight by twisting clockwise and making sure it doesn't come out or disconnect.
    • Reattach the headlight to the car with the 10 mm screws using a Phillips #0 screwdriver.
결론
To replace your headlight, follow these simple instructions.
작성자
1다른 기여자 명과 함께
Nadia Simpson
회원 가입일: 10/12/20
421 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 50
전체 시간: 3,582
