주요 콘텐츠로 건너뛰기
2004 Honda Pilot Timing Belt Replacement
필요한 것
  1. 2004 Honda Pilot Timing Belt Replacement, Timing Belt: 1 단계, 이미지 1/1
    • Looking from above showing the accessory belts removed along with the motor mount.
  2. 2004 Honda Pilot Timing Belt Replacement: 2 단계, 이미지 1/1
    • Side view showing same including the lower cover
  3. 2004 Honda Pilot Timing Belt Replacement: 3 단계, 이미지 1/1
    • Crank pulley bolt removal (loosen the bolt before removing the motor mount!)
  4. 2004 Honda Pilot Timing Belt Replacement: 4 단계, 이미지 1/1
    • Lower cover showing crank end and lower part of the dipstick tube (hydraulic tensioner can be seen behind VTEC solenoid) (crank timing mark can also be seen)
  5. 2004 Honda Pilot Timing Belt Replacement: 5 단계, 이미지 1/1
    • Upper and lower covers removed (12mm power steering adjuster nut shown)
  6. 2004 Honda Pilot Timing Belt Replacement: 6 단계, 이미지 1/1
    • Lower cover removed (rubber plug in the dipstick opening to prevent trash from falling in)
  7. 2004 Honda Pilot Timing Belt Replacement: 7 단계, 이미지 1/1
    • Different angle to show both 14mm pulley bolts
  8. 2004 Honda Pilot Timing Belt Replacement: 8 단계, 이미지 1/1
    • Top view showing timing belt, tensioner, and pulleys off
  9. 2004 Honda Pilot Timing Belt Replacement: 9 단계, 이미지 1/1
    • Top view showing water pump. Also showing the belt, pulleys, and tensioner removed
  10. 2004 Honda Pilot Timing Belt Replacement: 10 단계, 이미지 1/1
    • Bottom view showing the belt, pulleys, and tensioner removed
  11. 2004 Honda Pilot Timing Belt Replacement: 11 단계, 이미지 1/1
    • Bolt (silver one closer to the front of the block) with thread lock
  12. 2004 Honda Pilot Timing Belt Replacement: 12 단계, 이미지 1/1
    • Old parts and removed parts
  13. 2004 Honda Pilot Timing Belt Replacement: 13 단계, 이미지 1/1
    • Old parts, lower cover, motor mount
  14. 2004 Honda Pilot Timing Belt Replacement: 14 단계, 이미지 1/1
    • Covers, mount, dipstick (and new o-ring)
  15. 2004 Honda Pilot Timing Belt Replacement: 15 단계, 이미지 1/1
    • Various tools used (bag shows the part number for the trim clips)
결론
This job is a great example where parts are cheap and labor is expensive. If you are able to do this yourself you can easily save 80% of your bill.
다른 한 분이 해당 안내서를 완성하였습니다.
Collin Smith
회원 가입일: 05/24/12
28 평판
안내서 1개 작성함
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 34
전체 시간: 2,959
