주요 콘텐츠로 건너뛰기
2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly
필요한 것
  1. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, Stereo Unit: 1 단계, 이미지 1개 중 1개
    • This is the front panel of the 2004 Mazda 3 Stereo-CD Player. It's listed under the model number: BN85-66-9RXA.
  2. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 2 단계, 이미지 1개 중 1개
    • On the right side of the unit, designated by the letter R, remove 6 screws using a Phillips #2 screwdriver.
  3. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 3 단계, 이미지 1개 중 1개
    • On the left side of unit, designated by the letter L, remove 6 screws using a Phillips #2 screwdriver.
    • Gently pull on the cable to disconnect it from the front panel.
    • Now you can fully detach the front panel as well as the LCD display from the unit.
  4. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 4 단계, 이미지 1개 중 1개
    • On the top of the unit, remove 2 screws with a Phillips #2 screwdriver.
    • Lift and remove the top case from the unit.
  5. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 5 단계, 이미지 1개 중 1개
    • On the bottom of the unit, remove 2 screws with the Phillips #2 screwdriver.
  6. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 6 단계, 이미지 1개 중 1개
    • On the back of the unit, remove 8 screws with a Phillips #2 screwdriver.
    • Remove 1 screw with a Phillips #1 screwdriver.
    • Pull off both the bottom and top metal plates.
  7. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 7 단계, 이미지 1개 중 1개
    • On the front of the unit, remove 4 screws with a Phillips #2 screwdriver.
  8. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 8 단계, 이미지 1개 중 1개
    • On the left side of the unit, designated by the letter L, remove 2 screws with a Phillips #2 screwdriver.
  9. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 9 단계, 이미지 1개 중 1개
    • On the right side of the unit, designated by the letter R, remove 2 screws with a Phillips #2 screwdriver.
    • Pull the front metal plate off the unit. Then lift the CD drive from the lower metal case.
  10. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, CD Drive: 10 단계, 이미지 1개 중 1개
    • Remove 2 screws with a Phillips #1 screwdriver from the front of the CD drive.
    • Very gently pull apart the top metal case from the CD drive without damaging the ribbon cable.
  11. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 11 단계, 이미지 1개 중 1개
    • Gently pull the ribbon cable from the connector on the CD drive logic board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Robin Nystrom
회원 가입일: 06/13/16
182 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 31
지난 30일: 142
전체 시간: 5,749
