In this guide we will simply replace the window of the vehicle in the easiest way possible for the average person who may have little experience in fixing or dealing with cars. With enough patience, anyone could do this fix and save tons of money, as opposed to taking it to a dealership or repair shop, where the costs of repair would be much higher.
Remove the 3 screws holding the speaker in place using the Phillips #3 screwdriver.
On the final screw, hold the speaker part with one hand to make sure it does not fall off onto a hard surface and get damaged.
Lift the speaker out and set it nearby, being careful not to pull excessively on the wire connected to it.
It may be useful to set the speaker within the cabin, or to place it on a box beside the door panel, but it will all depend on how long the speaker cable is.
Roll the window up after loosening the roller screws in the previous step.
After rolling up the window, simply use two hands to carefully remove the window.
You may need a second person to remove the window and put in the new one, as this will prevent a window from falling and shattering, which may cause injury.
Roll down the window all the way again and replace the two screws in the bottom-left corner and speaker hole with the 5/32 Allen key to secure the window rollers.
Align the door panel and the metal frame of the door, then using a mallet or your hand, pop the panel back into place carefully.
Make sure that when using your hand or mallet to put the door panel back in, you do not apply too much pressure as it may cause the plastic clips of the door panel to crack.
