주요 콘텐츠로 건너뛰기
2005-2009 Subaru Outback Cabin Air Filter Replacement
필요한 것
  1. 2005-2009 Subaru Outback Cabin Air Filter Replacement, Remove the right dashboard panel: 1 단계, 이미지 1개 중 1개
    • Remove all contents in the glove box.
    • Gently pry and pull out the dashboard panel located at the right side of the glove box.
  2. 2005-2009 Subaru Outback Cabin Air Filter Replacement, Remove the glove box: 2 단계, 이미지 1개 중 1개
    • Unscrew the screw that holds the pin on the right hinge of the glove box.
    • Disconnect the damper (string) locate on the right side of the glove box.
    • Push in the sides of the glove box to release the knock pins.
    • Remove the glove box by disengaging the left hinge.
  3. 2005-2009 Subaru Outback Cabin Air Filter Replacement, Remove the upper storage box: 3 단계, 이미지 2개 중 1개 2005-2009 Subaru Outback Cabin Air Filter Replacement, Remove the upper storage box: 3 단계, 이미지 2개 중 2개
    • Remove the 3 screws on the left side of the upper storage box.
    • Pull out the upper storage box.
  4. 2005-2009 Subaru Outback Cabin Air Filter Replacement, Remove bracket: 4 단계, 이미지 1개 중 1개
    • Remove the screws to take out the bracket from hole where the storage box was removed.
    • Peel off Velcro tape attaching the insulator, and push up the insulator.
  5. 2005-2009 Subaru Outback Cabin Air Filter Replacement, Remove & replace filter: 5 단계, 이미지 1개 중 1개
    • Press inward the four tabs on the filter housing and the filter tray out. You need to slide the tray below the upper storage support.
    • Replace the filter. The air flow arrow on the filter must point down.
결론
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
2다른 기여자 명과 함께
Emme
회원 가입일: 06/15/17
823 평판
안내서 4개를 작성함
댓글 한 개
On right hand drive car only needed to take out glovebox lid and shelf!
willywigan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 25
지난 30일: 85
전체 시간: 10,495
