주요 콘텐츠로 건너뛰기
2005-2009 Subaru Outback Low Beam Headlight Replacement
필요한 것
  1. 2005-2009 Subaru Outback Low Beam Headlight Replacement, Low Beam Headlight: 1 단계, 이미지 2개 중 1개 2005-2009 Subaru Outback Low Beam Headlight Replacement, Low Beam Headlight: 1 단계, 이미지 2개 중 2개
    • Pull the hood lock on the driver's side.
    • Reach under the hood.
    • Push the lever under the hood to the left.
    • Pull the hood up.
  2. 2005-2009 Subaru Outback Low Beam Headlight Replacement: 2 단계, 이미지 2개 중 1개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the hood rod and place it in the hole on the passenger's side to prop up the hood.
  3. 2005-2009 Subaru Outback Low Beam Headlight Replacement: 3 단계, 이미지 3개 중 1개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 3 단계, 이미지 3개 중 2개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the plastic clip holding the windshield washer fluid tank by wedging a flat head screwdriver under the head of the clip and then pulling up on the clip.
    • Push the tank forward and out of the way.
  4. 2005-2009 Subaru Outback Low Beam Headlight Replacement: 4 단계, 이미지 3개 중 1개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 4 단계, 이미지 3개 중 2개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the plastic clips holding the air duct on the passengers side by wedging a flat head screwdriver under the head of the clip and then pulling up on the clip.
    • Grab the duct with both hands and pull up and back.
  5. 2005-2009 Subaru Outback Low Beam Headlight Replacement: 5 단계, 이미지 2개 중 1개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 5 단계, 이미지 2개 중 2개
    • Twist the white bulb covers counter-clockwise.
    • Pull the covers off.
  6. 2005-2009 Subaru Outback Low Beam Headlight Replacement: 6 단계, 이미지 2개 중 1개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 6 단계, 이미지 2개 중 2개
    • Unplug the bulb.
  7. 2005-2009 Subaru Outback Low Beam Headlight Replacement: 7 단계, 이미지 3개 중 1개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 7 단계, 이미지 3개 중 2개 2005-2009 Subaru Outback Low Beam Headlight Replacement: 7 단계, 이미지 3개 중 3개
    • Press the metal clip to release the bulb.
    • Remove the old bulb.
  8. 2005-2009 Subaru Outback Low Beam Headlight Replacement: 8 단계, 이미지 1개 중 1개
    • Place the new bulb in the socket.
    • The bulb must be inserted with the metal tab pointing downwards.
    • Do not touch the bulb glass as that can shorten the life of the bulb.
결론
작성자
2다른 기여자 명과 함께
Fernando Vargas
회원 가입일: 01/26/23
157 평판
안내서 1개를 작성함
UC Davis, Team 1-9, Morris Winter 2023 UC Davis, Team 1-9, Morris Winter 2023 회원
UCD-MORRIS-W23S1G9
2 회원들
안내서 1개 작성
댓글 한 개
Step 8
Rather: The TAB must fit into its slot which is NOT straight down by ant means.
David Strong - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 27
지난 30일: 95
전체 시간: 4,575
