주요 콘텐츠로 건너뛰기
2005-2007 Ford Focus Front Brake Pad Replacement
필요한 것
  1. 2005-2007 Ford Focus Front Brake Pad Replacement, Front Wheel: 1 단계, 이미지 1/1
    • Put the car in park (automatic) or neutral (manual).
    • Apply the parking brake.
    • Place chocks behind the rear wheels.
  2. 2005-2007 Ford Focus Front Brake Pad Replacement: 2 단계, 이미지 1/1
    • Use a 19 mm lug wrench to loosen each lug nut a half turn.
  3. 2005-2007 Ford Focus Front Brake Pad Replacement: 3 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 3 단계, 이미지 2/2
    • Use a hydraulic jack on the car's frame to jack the car.
    • A small notch shows where to place the jack.
    • It is only necessary to jack the car until the wheel no longer touches the ground.
  4. 2005-2007 Ford Focus Front Brake Pad Replacement: 4 단계, 이미지 1/1
    • Place a jack stand on the frame and remove the jack.
    • Never work on or underneath a car that is only supported by a jack. The car may fall, causing serious injury, or even death.
  5. 2005-2007 Ford Focus Front Brake Pad Replacement: 5 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 5 단계, 이미지 2/2
    • Use a lug wrench to completely remove the four lug nuts.
    • Remove the wheel.
  6. 2005-2007 Ford Focus Front Brake Pad Replacement, Front Brake Pads: 6 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement, Front Brake Pads: 6 단계, 이미지 2/2
    • The brake fluid reservoir is located towards the back of the engine compartment.
    • Unscrew the cap and remove it.
    • Be careful when handling brake fluid. Wash hands immediately if they come in contact with it. Do not let the fluid touch any painted parts; it will strip the paint.
  7. 2005-2007 Ford Focus Front Brake Pad Replacement: 7 단계, 이미지 1/1
    • Use a turkey baster to remove 2-3 ounces of brake fluid from the reservoir.
    • Never let the fluid level drop below the minimum mark. This will let air into your lines, which will require bleeding to remove.
    • Properly dispose of old brake fluid. Do not reuse it.
  8. 2005-2007 Ford Focus Front Brake Pad Replacement: 8 단계, 이미지 1/1
    • Use a flat head screwdriver or brake spoon to remove the outer pad retaining clip.
    • The clip has a lot of spring energy. Hold onto it with a pair of pliers when removing it to keep it from flying off and injuring someone.
  9. 2005-2007 Ford Focus Front Brake Pad Replacement: 9 단계, 이미지 1/1
    • Use a flat head screwdriver to remove the black plastic guide bolt dust caps.
  10. 2005-2007 Ford Focus Front Brake Pad Replacement: 10 단계, 이미지 1/1
    • Use a 7 mm Allen wrench to remove the two caliper guide bolts.
    • On the driver's side, turn towards the rear of the car. On the passenger side, turn towards the front
  11. 2005-2007 Ford Focus Front Brake Pad Replacement: 11 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 11 단계, 이미지 2/2
    • Remove the clip that holds the brake line to the strut with a pair of vise grips.
    • Pull the brake line towards you and out of the bracket.
  12. 2005-2007 Ford Focus Front Brake Pad Replacement: 12 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 12 단계, 이미지 2/2
    • Pull the caliper off of the rotor.
    • Place the caliper on top of a box or bucket so the brake line doesn't stretch or kink.
  13. 2005-2007 Ford Focus Front Brake Pad Replacement: 13 단계, 이미지 1/1
    • Pull the outer brake pad from the mounting bracket.
  14. 2005-2007 Ford Focus Front Brake Pad Replacement: 14 단계, 이미지 1/1
    • Remove the inner brake pad from the caliper.
    • The pad is held in place by three metal clips. It may take some force and wiggling to free the pad.
  15. 2005-2007 Ford Focus Front Brake Pad Replacement: 15 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 15 단계, 이미지 2/2
    • This step is only necessary if you are replacing the guide bolt bushings.
    • Use a flat head screwdriver to push the bushing through its hole in the caliper.
    • Remove the bushing from the caliper.
  16. 2005-2007 Ford Focus Front Brake Pad Replacement: 16 단계, 이미지 1/1
    • Clean the rotor, caliper, and all other hardware with an aerosol brake cleaner.
    • Never use compressed air to clean brake components. Brakes contain asbestos, and blowing the particles into the air could cause serious respiratory problems if inhaled.
  17. 2005-2007 Ford Focus Front Brake Pad Replacement: 17 단계, 이미지 1/1
    • Coat the steel backing plates of the new brake pads with an anti-squeal coating.
  18. 2005-2007 Ford Focus Front Brake Pad Replacement: 18 단계, 이미지 1/1
    • Place the new outer pad on the mounting bracket.
    • Small particles are a common cause of brake noise. Make sure pad and rotor surfaces are clean of all dirt and debris before installing.
  19. 2005-2007 Ford Focus Front Brake Pad Replacement: 19 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 19 단계, 이미지 2/2
    • This step is only necessary if the guide bolt bushings were removed.
    • Insert the new bushing from the inside of the caliper.
    • Use a flat head screwdriver to help feed the bushing through its hole.
  20. 2005-2007 Ford Focus Front Brake Pad Replacement: 20 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 20 단계, 이미지 2/2
    • Compress the caliper piston with a C-clamp.
    • Continually check the fluid level in the brake fluid reservoir to make sure it doesn't exceed the maximum level.
    • Install the new inner pad by pressing it into the caliper and making sure the clips are secure.
  21. 2005-2007 Ford Focus Front Brake Pad Replacement: 21 단계, 이미지 1/1
    • Place the caliper back on the rotor.
  22. 2005-2007 Ford Focus Front Brake Pad Replacement: 22 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 22 단계, 이미지 2/2
    • Grease the two guide bolts and reinstall them.
    • Guide bolts should be torqued to 21 foot-pounds.
    • Reinstall the guide bolt dust caps.
  23. 2005-2007 Ford Focus Front Brake Pad Replacement: 23 단계, 이미지 1/1
    • Place the brake line back in the bracket on the strut.
    • Secure the brake line with the retaining clip. Use the blunt end of a wrench to knock it completely into place.
  24. 2005-2007 Ford Focus Front Brake Pad Replacement: 24 단계, 이미지 1/1
    • Reinstall the retainer clip by first inserting the ends into the two holes in the caliper, then use pliers to stretch the ends onto the mounting bracket.
    • It is always a good idea to use white lithium grease wherever you have metal-on-metal contact.
  25. 2005-2007 Ford Focus Front Brake Pad Replacement: 25 단계, 이미지 1/1
    • Put the wheels back on the car and hand tighten the lug nuts.
    • Lower the car and completely tighten the lug nuts
    • Lug nuts should torqued to 94 foot-pounds.
  26. 2005-2007 Ford Focus Front Brake Pad Replacement: 26 단계, 이미지 1/2 2005-2007 Ford Focus Front Brake Pad Replacement: 26 단계, 이미지 2/2
    • Place the cap back on the brake fluid reservoir.
    • Turn the key to the "on" position. Press the brake pedal a few times. It should go to the floor once, and then become firm.
    • Fill the brake fluid reservoir with new fluid, if needed.
    • Replace the brake fluid reservoir cap, close the hood, and lower the car.
결승점
다른 24명이 해당 안내서를 완성하였습니다.
David Hodson
회원 가입일: 04/13/10
150,352 평판
안내서 127개 작성하였습니다
댓글 8개
Thank you, I found your instructions very helpful indeed but I am still not sure if I should bleed the brakes afterwards and if so which wheel do I start at?
Sally - 답글
When removing the guide pins they seem very hard to remove with an Allen/Hex key .. any tips?
khalz - 답글
Excellent guide --- many thanks ! Also applicable with virtually no modifications to my 2012 Ford Ikon, except that on my car the guide pins needed a size 45 Torx bit to unscrew. I had to replace the rotors as well, and discovered Ford had used threadlocking compound on the mounting bolts for the bracket, making them the devil to remove without pneumatic wrench. Threadlocking compound should be outlawed !!
GEB
GEB - 답글
Awesome guide. Very helpful. No trouble at all.
Miguel Martinez - 답글
Top effort… just saved myself £25!
rehan abdul-halim - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 123
전체 시간: 139,377
