주요 콘텐츠로 건너뛰기
2005 Ford Focus ZXW Tail Light Bulb Replacement
필요한 것
  1. 2005 Ford Focus ZXW Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 1/2 2005 Ford Focus ZXW Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 2/2
    • Open the trunk door.
  2. 2005 Ford Focus ZXW Tail Light Bulb Replacement: 2 단계, 이미지 1/2 2005 Ford Focus ZXW Tail Light Bulb Replacement: 2 단계, 이미지 2/2
    • Remove the two screws with the Phillips screwdriver, rotating counter clockwise.
    • The taillight housing can now be detached from the vehicle.
  3. 2005 Ford Focus ZXW Tail Light Bulb Replacement: 3 단계, 이미지 1/3 2005 Ford Focus ZXW Tail Light Bulb Replacement: 3 단계, 이미지 2/3 2005 Ford Focus ZXW Tail Light Bulb Replacement: 3 단계, 이미지 3/3
    • Gently pull the detached taillight housing away from the vehicle.
    • There will be wires attached to two different bulb sockets.
  4. 2005 Ford Focus ZXW Tail Light Bulb Replacement: 4 단계, 이미지 1/2 2005 Ford Focus ZXW Tail Light Bulb Replacement: 4 단계, 이미지 2/2
    • Disconnect the harness from the bulb socket by pushing in on the tabs and pulling.
    • Removing the harness from the bulb socket might require some force. Try moving the harness back and forth while pushing on the tabs if you are having trouble removing the harness.
    • Repeat the last two steps to disconnect the second harness from the bulb socket.
  5. 2005 Ford Focus ZXW Tail Light Bulb Replacement: 5 단계, 이미지 1/2 2005 Ford Focus ZXW Tail Light Bulb Replacement: 5 단계, 이미지 2/2
    • Remove the damaged bulb by firmly gripping the bulb and pulling.
    • Removing the bulb from the socket may require some force.
    • Be careful while handling the bulb as it may break.
  6. 2005 Ford Focus ZXW Tail Light Bulb Replacement: 6 단계, 이미지 1/2 2005 Ford Focus ZXW Tail Light Bulb Replacement: 6 단계, 이미지 2/2
    • Place the new bulb in the bulb socket.
    • Repeat this process to replace the second bulb.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Megn Thomason
회원 가입일: 02/13/22
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 42
전체 시간: 875
