주요 콘텐츠로 건너뛰기
2005 Honda Accord Cabin Air Filter Replacement
필요한 것
  1. 2005 Honda Accord Cabin Air Filter Replacement, Open the glove box: 1 단계, 이미지 1/2 2005 Honda Accord Cabin Air Filter Replacement, Open the glove box: 1 단계, 이미지 2/2
    • Locate the glove compartment on the passenger side of the vehicle.
    • Unlatch the glove compartment and allow it to fully open.
  2. 2005 Honda Accord Cabin Air Filter Replacement, Unhook the glove box damper arm latch: 2 단계, 이미지 1/2 2005 Honda Accord Cabin Air Filter Replacement, Unhook the glove box damper arm latch: 2 단계, 이미지 2/2
    • Locate the glove box damper assy latch on the right side of the glove compartment.
    • Unhook the latch from the glove compartment by pushing it towards the front of the car.
  3. 2005 Honda Accord Cabin Air Filter Replacement, Release the glove box stops: 3 단계, 이미지 1/2 2005 Honda Accord Cabin Air Filter Replacement, Release the glove box stops: 3 단계, 이미지 2/2
    • Firmly grab both sides of the glove compartment.
    • Push the sides of the glove compartment inward and drop the entire glove box down to release it from the dashboard. Support the glove box with your leg.
  4. 2005 Honda Accord Cabin Air Filter Replacement, Remove the cabin air filter tray: 4 단계, 이미지 1/3 2005 Honda Accord Cabin Air Filter Replacement, Remove the cabin air filter tray: 4 단계, 이미지 2/3 2005 Honda Accord Cabin Air Filter Replacement, Remove the cabin air filter tray: 4 단계, 이미지 3/3
    • Locate the cover for the cabin air filter and notice the two tabs on either side.
    • Press on both tabs of the cover and pull the cover outwards towards you to reveal the cabin air filter.
    • Pull the cover all the way out.
  5. 2005 Honda Accord Cabin Air Filter Replacement, Remove and replace the cabin air filter: 5 단계, 이미지 1/2 2005 Honda Accord Cabin Air Filter Replacement, Remove and replace the cabin air filter: 5 단계, 이미지 2/2
    • Pull the air filter out of the cover.
    • When putting in the new filter, be sure to line up the air flow arrows on the filter with the arrows on the front of the cover.
결론
Reinstall the cabin air filter tray, and reinstall the glove box in reverse order as the earlier steps.
다른 5명이 해당 안내서를 완성하였습니다.
Frank
회원 가입일: 04/14/14
267 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-35, Maness Spring 2014 Cal Poly, Team 12-35, Maness Spring 2014 회원
CPSU-MANESS-S14S12G35
4 회원들
안내서 5개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 99
전체 시간: 11,893
