이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the glove compartment on the passenger side of the vehicle.
Unlatch the glove compartment and allow it to fully open.
Locate the glove box damper assy latch on the right side of the glove compartment.
Unhook the latch from the glove compartment by pushing it towards the front of the car.
Firmly grab both sides of the glove compartment.
Push the sides of the glove compartment inward and drop the entire glove box down to release it from the dashboard. Support the glove box with your leg.
Locate the cover for the cabin air filter and notice the two tabs on either side.
Press on both tabs of the cover and pull the cover outwards towards you to reveal the cabin air filter.
Pull the cover all the way out.
Pull the air filter out of the cover.
When putting in the new filter, be sure to line up the air flow arrows on the filter with the arrows on the front of the cover.
다른 7명이 해당 안내서를 완성하였습니다.
