주요 콘텐츠로 건너뛰기
2005 Honda Accord Engine Air Filter Replacement
필요한 것
  1. 2005 Honda Accord Engine Air Filter Replacement, 2005 Honda Accord Opening Hood Guide: 1 단계, 이미지 1/2 2005 Honda Accord Engine Air Filter Replacement, 2005 Honda Accord Opening Hood Guide: 1 단계, 이미지 2/2
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  2. 2005 Honda Accord Engine Air Filter Replacement: 2 단계, 이미지 1/3 2005 Honda Accord Engine Air Filter Replacement: 2 단계, 이미지 2/3 2005 Honda Accord Engine Air Filter Replacement: 2 단계, 이미지 3/3
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
  3. 2005 Honda Accord Engine Air Filter Replacement, Engine Air Filter: 3 단계, 이미지 1/1
    • Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
  4. 2005 Honda Accord Engine Air Filter Replacement: 4 단계, 이미지 1/1
    • Unscrew the four bolts in the corners of the Air Filter Housing. This loosens the top of the housing from the bottom of the housing.
    • The bolts cannot be completely removed.
  5. 2005 Honda Accord Engine Air Filter Replacement: 5 단계, 이미지 1/3 2005 Honda Accord Engine Air Filter Replacement: 5 단계, 이미지 2/3 2005 Honda Accord Engine Air Filter Replacement: 5 단계, 이미지 3/3
    • Next, separate the air filter housing from the bottom of the housing. To do this, with both hands, grab the Air Filter Housing from the exterior and push towards the engine block while pulling up.
    • It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing.
  6. 2005 Honda Accord Engine Air Filter Replacement: 6 단계, 이미지 1/2 2005 Honda Accord Engine Air Filter Replacement: 6 단계, 이미지 2/2
    • Remove the old air filter by gently pulling it from the top of the Air Filter housing.
    • Replace the old air filter with a new one. The blue side should be facing down.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Matt Ondriezek
회원 가입일: 04/14/14
486 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-35, Maness Spring 2014 Cal Poly, Team 12-35, Maness Spring 2014 회원
CPSU-MANESS-S14S12G35
4 회원들
안내서 5개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 57
전체 시간: 5,307
