이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
An engine air filter is needed to filter the air flowing into the engine.
필요한 것
Identify the open hood latch. It is located to the left of your brake pedal.
Pull latch toward you. You should hear a click from the front of the car.
Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
다른 4명이 해당 안내서를 완성하였습니다.
