주요 콘텐츠로 건너뛰기
2005 Honda Accord Headlight Replacement
필요한 것
  1. 2005 Honda Accord Headlight Replacement, Headlight Bulb: 1 단계, 이미지 1/1
    • Pop open the hood of the vehicle.
  2. 2005 Honda Accord Headlight Replacement: 2 단계, 이미지 1/3 2005 Honda Accord Headlight Replacement: 2 단계, 이미지 2/3 2005 Honda Accord Headlight Replacement: 2 단계, 이미지 3/3
    • Remove the headlight connector by depressing the clip and pulling it away from the vehicle.
  3. 2005 Honda Accord Headlight Replacement: 3 단계, 이미지 1/2 2005 Honda Accord Headlight Replacement: 3 단계, 이미지 2/2
    • Turn the headlight counter clockwise to release it from the headlight assembly.
  4. 2005 Honda Accord Headlight Replacement: 4 단계, 이미지 1/2 2005 Honda Accord Headlight Replacement: 4 단계, 이미지 2/2
    • Pull the headlight bulb out of the socket.
  5. 2005 Honda Accord Headlight Replacement: 5 단계, 이미지 1/2 2005 Honda Accord Headlight Replacement: 5 단계, 이미지 2/2
    • Inspect your old headlight bulb and compare with new one to ensure it is the same.
  6. 2005 Honda Accord Headlight Replacement: 6 단계, 이미지 1/1
    • Align notches and insert the headlight bulb into the socket.
  7. 2005 Honda Accord Headlight Replacement: 7 단계, 이미지 1/1
    • Turn it clockwise until the headlight clips in.
  8. 2005 Honda Accord Headlight Replacement: 8 단계, 이미지 1/1
    • Reconnect the headlight pigtail.
    • You will hear a click when the connector is fully seated.
  9. 2005 Honda Accord Headlight Replacement: 9 단계, 이미지 1/3 2005 Honda Accord Headlight Replacement: 9 단계, 이미지 2/3 2005 Honda Accord Headlight Replacement: 9 단계, 이미지 3/3
    • Turn on the vehicle to make sure the headlight lights up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Diego Avila
회원 가입일: 10/05/21
180 평판
안내서 1개 작성함
CSU Los Angeles, Team 11-69, Grodsky Fall 2021 CSU Los Angeles, Team 11-69, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G69
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 71
전체 시간: 1,386
