주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
2005 Honda Accord Opening Hood Guide
  1. 2005 Honda Accord Opening Hood Guide, 2005 Honda Accord Opening Hood Guide: 1 단계, 이미지 1/2 2005 Honda Accord Opening Hood Guide, 2005 Honda Accord Opening Hood Guide: 1 단계, 이미지 2/2
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  2. 2005 Honda Accord Opening Hood Guide: 2 단계, 이미지 1/3 2005 Honda Accord Opening Hood Guide: 2 단계, 이미지 2/3 2005 Honda Accord Opening Hood Guide: 2 단계, 이미지 3/3
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
결론
To close hood, lower to 6 inches above engine, then drop hood. If you do not hear the latch reengage, push down on hood or try dropping hood from a higher level.
다른 4명이 해당 안내서를 완성하였습니다.
Matt Ondriezek
회원 가입일: 04/14/14
486 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-35, Maness Spring 2014 Cal Poly, Team 12-35, Maness Spring 2014 회원
CPSU-MANESS-S14S12G35
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Don’t you think that people usually access this guide when the hood is stuck closed? In which case these instructions are no more helpful than those in the owner’s manual. I’ve opened the hood of my 2005 Honda Civic countless times, until this morning. Interior release functions just fine, but the secondary release does nothing.
David - 답글
Cable from inside hood release is broken need diagrams to show mechanism under driver's side fender to show how to replace it.
William McNeil - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 63
전체 시간: 37,772
