주요 콘텐츠로 건너뛰기
2005 Honda Pilot Rear Strut Replacement
필요한 것
  1. 2005 Honda Pilot Rear Strut Replacement, Rear Struts: 1 단계, 이미지 1/1
    • Begin by placing a support beneath the trunk that takes all the weight of the trunk.
  2. 2005 Honda Pilot Rear Strut Replacement: 2 단계, 이미지 1/1
    • Insert the flat head screwdriver under the clip, at the top of the strut, and lift the clip until it pops off completely.
  3. 2005 Honda Pilot Rear Strut Replacement: 3 단계, 이미지 1/1
    • Now, insert the flat head screwdriver under the clip, at the bottom of the strut, and lift the clip until it pops off completely.
  4. 2005 Honda Pilot Rear Strut Replacement: 4 단계, 이미지 1/1
    • Line up the ball and the socket pieces of your new strut.
  5. 2005 Honda Pilot Rear Strut Replacement: 5 단계, 이미지 1/1
    • Use force to push the strut and connect the ball and socket joint.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kayla Peterson
회원 가입일: 02/04/19
175 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 202
