주요 콘텐츠로 건너뛰기
2005 Honda S2000 Valve Cover Gasket Replacement
필요한 것
  1. 2005 Honda S2000 Valve Cover Gasket Replacement, Valve Cover Gasket: 1 단계, 이미지 1/3 2005 Honda S2000 Valve Cover Gasket Replacement, Valve Cover Gasket: 1 단계, 이미지 2/3 2005 Honda S2000 Valve Cover Gasket Replacement, Valve Cover Gasket: 1 단계, 이미지 3/3
    • Using a 3/8" drive ratchet, remove the four screws that hold on the spark plug cover.
  2. 2005 Honda S2000 Valve Cover Gasket Replacement: 2 단계, 이미지 1/3 2005 Honda S2000 Valve Cover Gasket Replacement: 2 단계, 이미지 2/3 2005 Honda S2000 Valve Cover Gasket Replacement: 2 단계, 이미지 3/3
    • Unplug both plugs on the back of the valve cover.
    • Undo the clip holding the wire harness.
  3. 2005 Honda S2000 Valve Cover Gasket Replacement: 3 단계, 이미지 1/3 2005 Honda S2000 Valve Cover Gasket Replacement: 3 단계, 이미지 2/3 2005 Honda S2000 Valve Cover Gasket Replacement: 3 단계, 이미지 3/3
    • Using a 10mm deep socket and a Torque wrench, remove the four 10mm bolts from all four coil packs.
  4. 2005 Honda S2000 Valve Cover Gasket Replacement: 4 단계, 이미지 1/3 2005 Honda S2000 Valve Cover Gasket Replacement: 4 단계, 이미지 2/3 2005 Honda S2000 Valve Cover Gasket Replacement: 4 단계, 이미지 3/3
    • Only unplug the last coil pack. Then pull all the coil packs out of the spark plug holes.
  5. 2005 Honda S2000 Valve Cover Gasket Replacement: 5 단계, 이미지 1/3 2005 Honda S2000 Valve Cover Gasket Replacement: 5 단계, 이미지 2/3 2005 Honda S2000 Valve Cover Gasket Replacement: 5 단계, 이미지 3/3
    • Move connected coil packs over to make free space.
  6. 2005 Honda S2000 Valve Cover Gasket Replacement: 6 단계, 이미지 1/2 2005 Honda S2000 Valve Cover Gasket Replacement: 6 단계, 이미지 2/2
    • Loosen the clamps on both vacuum lines. Slide both lines off. Remove the oil dipstick and oil cap.
  7. 2005 Honda S2000 Valve Cover Gasket Replacement: 7 단계, 이미지 1/3 2005 Honda S2000 Valve Cover Gasket Replacement: 7 단계, 이미지 2/3 2005 Honda S2000 Valve Cover Gasket Replacement: 7 단계, 이미지 3/3
    • Use both hands and slowly and evenly pull up on the valve cover.
    • Clean any oil residue from the surface where the valve cover sits.
  8. 2005 Honda S2000 Valve Cover Gasket Replacement: 8 단계, 이미지 1/2 2005 Honda S2000 Valve Cover Gasket Replacement: 8 단계, 이미지 2/2
    • Compare the old and new parts and make sure they are the same. Clean the inside of the valve cover with an old rag.
  9. 2005 Honda S2000 Valve Cover Gasket Replacement: 9 단계, 이미지 1/2 2005 Honda S2000 Valve Cover Gasket Replacement: 9 단계, 이미지 2/2
    • Apply a small amount of force on both sides of the cover. Gently wiggle it on and ensure nothing gets caught on it.
  10. 2005 Honda S2000 Valve Cover Gasket Replacement: 10 단계, 이미지 1/3 2005 Honda S2000 Valve Cover Gasket Replacement: 10 단계, 이미지 2/3 2005 Honda S2000 Valve Cover Gasket Replacement: 10 단계, 이미지 3/3
    • Put both vacuum lines back on and tighten them down with the clamps.
    • Put on the new washers that hold down the cover; these easily pop on.
  11. 2005 Honda S2000 Valve Cover Gasket Replacement: 11 단계, 이미지 1/2 2005 Honda S2000 Valve Cover Gasket Replacement: 11 단계, 이미지 2/2
    • Place the 4 coils back into the spark plug holes and tighten the bolts. Plug in the last coil pack.
    • Plug in the last coil pack.
    • Tighten the five bolts that hold down the valve cover.
  12. 2005 Honda S2000 Valve Cover Gasket Replacement: 12 단계, 이미지 1/2 2005 Honda S2000 Valve Cover Gasket Replacement: 12 단계, 이미지 2/2
    • Plug the two plugs back in on the back of the valve cover.
  13. 2005 Honda S2000 Valve Cover Gasket Replacement: 13 단계, 이미지 1/2 2005 Honda S2000 Valve Cover Gasket Replacement: 13 단계, 이미지 2/2
    • Tighten the spark plug cover with its 4 bolts.
    • Reattach the oil cap and oil dipstick.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Victor A Galaviz
회원 가입일: 10/23/20
291 평판
안내서 1개 작성함
CSU Los Angeles, Team S12-G3, Harris Fall 2020 CSU Los Angeles, Team S12-G3, Harris Fall 2020 회원
CSULA-HARRIS-F20S12G3
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 46
전체 시간: 2,165
