소개
Replacing the valve cover gasket can be a very easy process. If you need any help finding the right part, here is the part number: 12040-PCX-305. You can purchase the gasket on Honda Parts Now. When valve cover gaskets go bad, the engine might misfire or small like burning oil. Oil can also leak out of the valve cover if the gasket has gone bad.
This is a safe part replacement, so there is little risk of injury; however, wear gloves will protect your hands from oil residue and grime. Don’t lose any parts or screws and store them in a secure place such as a magnetic parts dish.
필요한 것
Using a 3/8" drive ratchet, remove the four screws that hold on the spark plug cover.
다른 한 분이 해당 안내서를 완성하였습니다.
