주요 콘텐츠로 건너뛰기
2005 Infiniti G35 Windshield Wiper Replacement
  1. 2005 Infiniti G35 Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 1/2 2005 Infiniti G35 Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 2/2
    • Lift up on the drivers side windshield wiper.
    • The wiper blade should stay in its upright position while you work.
  2. 2005 Infiniti G35 Windshield Wiper Replacement: 2 단계, 이미지 1/2 2005 Infiniti G35 Windshield Wiper Replacement: 2 단계, 이미지 2/2
    • Rotate the wiper blade 180 degrees so that it is parallel with the windshield.
  3. 2005 Infiniti G35 Windshield Wiper Replacement: 3 단계, 이미지 1/2 2005 Infiniti G35 Windshield Wiper Replacement: 3 단계, 이미지 2/2
    • Push down on the middle of the wiper blade until you hear/feel a click.
  4. 2005 Infiniti G35 Windshield Wiper Replacement: 4 단계, 이미지 1/3 2005 Infiniti G35 Windshield Wiper Replacement: 4 단계, 이미지 2/3 2005 Infiniti G35 Windshield Wiper Replacement: 4 단계, 이미지 3/3
    • Rotate the wiper blade back to its original position.
    • Pull down on the blade until it detaches from the wiper arm.
  5. 2005 Infiniti G35 Windshield Wiper Replacement: 5 단계, 이미지 1/3 2005 Infiniti G35 Windshield Wiper Replacement: 5 단계, 이미지 2/3 2005 Infiniti G35 Windshield Wiper Replacement: 5 단계, 이미지 3/3
    • Slide the new wiper blade onto the wiper arm in the same position that you removed the old blade.
    • Slide with moderate pressure until you hear a click.
  6. 2005 Infiniti G35 Windshield Wiper Replacement: 6 단계, 이미지 1/2 2005 Infiniti G35 Windshield Wiper Replacement: 6 단계, 이미지 2/2
    • Hold the wiper blade against the arm to gently lay the arm down without damaging the new wiper blade.
  7. 2005 Infiniti G35 Windshield Wiper Replacement: 7 단계, 이미지 1/1
    • Repeat steps 1-6 for the passenger side windshield wiper.
결론
Solomon Vlasak
회원 가입일: 10/09/20
150 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 22
전체 시간: 509
