주요 콘텐츠로 건너뛰기
2005 Jeep Liberty Fog Light Replacement
필요한 것
  1. 2005 Jeep Liberty Fog Light Replacement, Fog Light: 1 단계, 이미지 1/1
    • Open the hood to access the radiator grill tabs.
    • Pull up on the first tab and repeat for the remaining four tabs.
  2. 2005 Jeep Liberty Fog Light Replacement: 2 단계, 이미지 1/1
    • Tilt the radiator grill cover forward and lift up and out to remove.
  3. 2005 Jeep Liberty Fog Light Replacement: 3 단계, 이미지 1/1
    • Using an allen wrench, turn the tension screw counter-clockwise to loosen the light housing.
  4. 2005 Jeep Liberty Fog Light Replacement: 4 단계, 이미지 1/1
    • Lift up on the tension screw to release the light housing.
  5. 2005 Jeep Liberty Fog Light Replacement: 5 단계, 이미지 1/1
    • Using a flat-head screwdriver, pull the tab outward to remove the light housing.
    • Repeat the procedure for the right side of the light housing.
  6. 2005 Jeep Liberty Fog Light Replacement: 6 단계, 이미지 1/1
    • Pull the light housing toward you.
  7. 2005 Jeep Liberty Fog Light Replacement: 7 단계, 이미지 1/1
    • Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
  8. 2005 Jeep Liberty Fog Light Replacement: 8 단계, 이미지 1/1
    • Remove the light socket from the light housing by turning counter-clockwise.
  9. 2005 Jeep Liberty Fog Light Replacement: 9 단계, 이미지 1/1
    • Remove the light socket from the light housing and replace.
    • The light socket part number is 9145 and can be purchased at any auto parts store.
    • Install the new light socket back into the light housing by turning clockwise.
    • Plug the wiring harness back in the light socket.
결론
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
다른 2명이 해당 안내서를 완성하였습니다.
CHARLES CATLEDGE
회원 가입일: 09/17/17
188 평판
안내서 1개 작성함
Pasco Hernando, Team S4-G55, Prince Winter 2017 Pasco Hernando, Team S4-G55, Prince Winter 2017 회원
PHSC-PRINCE-W17S4G55
1 회원
안내서 1개 작성하였습니다
댓글 2개
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
vievie aryanti - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 29
전체 시간: 7,248
