주요 콘텐츠로 건너뛰기
2005 Mazda 6 Electronic Throttle Body Replacement
필요한 것
  1. 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: 1 단계, 이미지 1/3 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: 1 단계, 이미지 2/3 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: 1 단계, 이미지 3/3
    • Open the hood and prop it open.
    • Locate the electronic throttle body.
  2. 2005 Mazda 6 Electronic Throttle Body Replacement: 2 단계, 이미지 1/3 2005 Mazda 6 Electronic Throttle Body Replacement: 2 단계, 이미지 2/3 2005 Mazda 6 Electronic Throttle Body Replacement: 2 단계, 이미지 3/3
    • Detach the electric connection from the electronic throttle body.
    • Unplug the safety pin.
  3. 2005 Mazda 6 Electronic Throttle Body Replacement: 3 단계, 이미지 1/2 2005 Mazda 6 Electronic Throttle Body Replacement: 3 단계, 이미지 2/2
    • Unscrew the clamp that connects the intake hose to the air filter housing.
  4. 2005 Mazda 6 Electronic Throttle Body Replacement: 4 단계, 이미지 1/2 2005 Mazda 6 Electronic Throttle Body Replacement: 4 단계, 이미지 2/2
    • Unscrew the clamp that secures the intake hose with the electronic throttle body.
  5. 2005 Mazda 6 Electronic Throttle Body Replacement: 5 단계, 이미지 1/3 2005 Mazda 6 Electronic Throttle Body Replacement: 5 단계, 이미지 2/3 2005 Mazda 6 Electronic Throttle Body Replacement: 5 단계, 이미지 3/3
    • Disconnect the intake hose from both sides.
  6. 2005 Mazda 6 Electronic Throttle Body Replacement: 6 단계, 이미지 1/3 2005 Mazda 6 Electronic Throttle Body Replacement: 6 단계, 이미지 2/3 2005 Mazda 6 Electronic Throttle Body Replacement: 6 단계, 이미지 3/3
    • Disconnect the upper and lower vacuum hose on the electronic throttle body using a pair of pliers.
  7. 2005 Mazda 6 Electronic Throttle Body Replacement: 7 단계, 이미지 1/3 2005 Mazda 6 Electronic Throttle Body Replacement: 7 단계, 이미지 2/3 2005 Mazda 6 Electronic Throttle Body Replacement: 7 단계, 이미지 3/3
    • Remove the four screws connecting the electronic throttle body to the intake manifold.
  8. 2005 Mazda 6 Electronic Throttle Body Replacement: 8 단계, 이미지 1/2 2005 Mazda 6 Electronic Throttle Body Replacement: 8 단계, 이미지 2/2
    • Place the new electronic throttle body on the intake manifold.
  9. 2005 Mazda 6 Electronic Throttle Body Replacement: 9 단계, 이미지 1/2 2005 Mazda 6 Electronic Throttle Body Replacement: 9 단계, 이미지 2/2
    • Reattach the four screws securing the electronic throttle body with the intake manifold.
  10. 2005 Mazda 6 Electronic Throttle Body Replacement: 10 단계, 이미지 1/3 2005 Mazda 6 Electronic Throttle Body Replacement: 10 단계, 이미지 2/3 2005 Mazda 6 Electronic Throttle Body Replacement: 10 단계, 이미지 3/3
    • Connect the upper vacuum.
    • Connect the lower vacuum hose to the electronic throttle body.
  11. 2005 Mazda 6 Electronic Throttle Body Replacement: 11 단계, 이미지 1/3 2005 Mazda 6 Electronic Throttle Body Replacement: 11 단계, 이미지 2/3 2005 Mazda 6 Electronic Throttle Body Replacement: 11 단계, 이미지 3/3
    • Connect the intake hose on both sides.
    • Screw in the clamp that secures the intake hose to the electronic throttle body.
    • Screw the clamp that secures the intake hose to the air filter housing.
  12. 2005 Mazda 6 Electronic Throttle Body Replacement: 12 단계, 이미지 1/3 2005 Mazda 6 Electronic Throttle Body Replacement: 12 단계, 이미지 2/3 2005 Mazda 6 Electronic Throttle Body Replacement: 12 단계, 이미지 3/3
    • Connect the electric connection to the electronic throttle body.
  13. 2005 Mazda 6 Electronic Throttle Body Replacement: 13 단계, 이미지 1/2 2005 Mazda 6 Electronic Throttle Body Replacement: 13 단계, 이미지 2/2
    • The electronic throttle body replacement is done.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Yefri Gonzalez
회원 가입일: 04/04/22
244 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-71, Briggs Spring 2022 CSU Los Angeles, Team 4-71, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S4G71
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Bonjour j'ai un Mazda 6 de moteur Essence avec moi mais sa consomme trop et Quel est la solution pour d'autre me disent de changer le catalyseur d'autres me disent de changer la bougie
Sidi mohamed Coulibaly - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 25
30일 전: 94
전체 시간: 1,183
