주요 콘텐츠로 건너뛰기
2006-2013 Toyota Corolla Brake Light Replacement
필요한 것
  1. 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: 1 단계, 이미지 1/3 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: 1 단계, 이미지 2/3 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: 1 단계, 이미지 3/3
    • Open the trunk of the vehicle.
    • Locate the taillight area that needs fixing either on the right and/or left.
    • We are fixing the left side in this guide.
  2. 2006-2013 Toyota Corolla Brake Light Replacement: 2 단계, 이미지 1/1
    • Using a flathead screwdriver, pry the 3 fasteners out.
  3. 2006-2013 Toyota Corolla Brake Light Replacement: 3 단계, 이미지 1/2 2006-2013 Toyota Corolla Brake Light Replacement: 3 단계, 이미지 2/2
    • Pull back the covering to reveal the taillight area.
    • Locate the brake light bulb in the brown socket at the inner end of the taillight area.
  4. 2006-2013 Toyota Corolla Brake Light Replacement: 4 단계, 이미지 1/2 2006-2013 Toyota Corolla Brake Light Replacement: 4 단계, 이미지 2/2
    • Rotate the brown socket counterclockwise and pull out the socket.
    • Pull the nonfunctioning light bulb from its socket and replace with the new, functioning bulb
    • Put the brown socket back in place and rotate clockwise to secure it
    • Put the covering back in place and secure the 3 fasteners. No tools are required, simply push the fasteners into position.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Phuong khau
회원 가입일: 09/15/20
163 평판
안내서 1개 작성함
University of Memphis, Team S3-G18, Willis Fall 2020 University of Memphis, Team S3-G18, Willis Fall 2020 회원
UM-WILLIS-F20S3G18
1 회원
안내서 2개 작성하였습니다
댓글 2개
I had to use pliers carefully to turn the brown socket, but this worked perfectly. Thank you!
Josh - 답글
Wrong bulb #. Must order Sylvania 3157 for Brake Light .
https://www.partsource.ca/products/3157l...
fruitfly - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 81
30일 전: 346
전체 시간: 9,370
