주요 콘텐츠로 건너뛰기
2006-2013 Toyota Corolla Ignition Coil Replacement
필요한 것
  1. 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: 1 단계, 이미지 1/3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: 1 단계, 이미지 2/3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: 1 단계, 이미지 3/3
    • Pop the hood and remove the black plastic cover over the engine.
    • There is nothing to unscrew, or unlatch, and the cover should lift off. Once removed, the top of the engine will look like the third picture
  2. 2006-2013 Toyota Corolla Ignition Coil Replacement: 2 단계, 이미지 1/2 2006-2013 Toyota Corolla Ignition Coil Replacement: 2 단계, 이미지 2/2
    • Unplug the ignition coil you wish to replace. The coils are numbered one though four, left to right.
    • Do not unscrew the bolt on the ignition coil before this step. It makes the electrical plug more difficult to remove
  3. 2006-2013 Toyota Corolla Ignition Coil Replacement: 3 단계, 이미지 1/1
    • Unscrew the bolt of the coil that needs to be replaced.
    • Be sure to put the bolt in a place you will not lose it!
  4. 2006-2013 Toyota Corolla Ignition Coil Replacement: 4 단계, 이미지 1/2 2006-2013 Toyota Corolla Ignition Coil Replacement: 4 단계, 이미지 2/2
    • Pull the coil straight up and out. It should come off of the spark plug with little resistance.
  5. 2006-2013 Toyota Corolla Ignition Coil Replacement: 5 단계, 이미지 1/2 2006-2013 Toyota Corolla Ignition Coil Replacement: 5 단계, 이미지 2/2
    • Apply a pea-sized amount of grease to the new ignition coil. It should be all around the rubber tip around the bottom.
    • While not required, this step will make any future replacements much easier.
  6. 2006-2013 Toyota Corolla Ignition Coil Replacement: 6 단계, 이미지 1/1
    • When inserting the new ignition coil, press down lightly to ensure it is completely in place.
    • Re-plugging in the ignition coil, and re-screw it in. This can be preformed in either order.
    • Repeat steps three through five as necessary for the other three ignition coils.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Henderson Gillette
회원 가입일: 09/23/23
160 평판
안내서 1개 작성함
Austin Community College, Team 22-3, Watkins Fall 2023 Austin Community College, Team 22-3, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S22G3
2 회원들
안내서 2개 작성하였습니다
댓글 한 개
Excelente explicación, muy clara y detallada
Oscar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 76
30일 전: 375
전체 시간: 1,822
