주요 콘텐츠로 건너뛰기
2006-2013 Toyota Corolla Turn Signal Bulb Replacement
필요한 것
  1. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement, Turn Signal Bulb: 1 단계, 이미지 1/2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement, Turn Signal Bulb: 1 단계, 이미지 2/2
    • Pull the hood release lever towards yourself until the hood pops.
    • Open and move the bonnet lever towards the left to completely release the hood.
  2. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 2 단계, 이미지 1/2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 2 단계, 이미지 2/2
    • Lift the prop and place it inside bonnet hole to keep the hood open.
    • The hood prop will be located towards the front of the engine.
  3. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 3 단계, 이미지 1/2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 3 단계, 이미지 2/2
    • Turn your wheel to the appropriate side to locate the signal light.
    • For the left signal light, you would turn your wheel inwards to the right. While for the right side turn your wheel inwards by turning left.
  4. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 4 단계, 이미지 1/3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 4 단계, 이미지 2/3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 4 단계, 이미지 3/3
    • Pry off the clip under the wheel well using a flathead screwdriver.
    • Remove the lining by pulling it straight back.
    • Some cars are different and may need different tools. For example, some have nuts holding the liner so you'll need a wrench.
  5. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 5 단계, 이미지 1/1
    • Twist the signal housing counter-clockwise until it releases.
  6. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 6 단계, 이미지 1/3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 6 단계, 이미지 2/3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 6 단계, 이미지 3/3
    • With one hand grab the socket and with the other pull the bulb straight out of the socket.
  7. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 7 단계, 이미지 1/3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 7 단계, 이미지 2/3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 7 단계, 이미지 3/3
    • Insert the new bulb into the empty socket place the signal light back into the housing and twist it clockwise to the original position.
  8. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 8 단계, 이미지 1/3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 8 단계, 이미지 2/3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 8 단계, 이미지 3/3
    • Make sure your signal works properly by turning it on.
결론
Alexander
회원 가입일: 10/24/23
157 평판
안내서 1개 작성함
CSU Los Angeles, Team 8-1, Ribeiro Fall 2023 CSU Los Angeles, Team 8-1, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S8G1
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 26
30일 전: 73
전체 시간: 725
