주요 콘텐츠로 건너뛰기
2006-2011 Honda Civic Dome Light Replacement
필요한 것
  1. 2006-2011 Honda Civic Dome Light Replacement, Dome Light: 1 단계, 이미지 1/2 2006-2011 Honda Civic Dome Light Replacement, Dome Light: 1 단계, 이미지 2/2
    • Before replacing the dome light and to avoid a short circuit, disconnect the car battery first.
    • Open the hood of your car by pressing the front latch and lift the hood.
    • Carefully attach the hood strut, (located towards the left of your car's engine), into the slot to hold the weight of the hood.
    • Disconnect the positive terminal of the battery in order to avoid short circuits.
  2. 2006-2011 Honda Civic Dome Light Replacement: 2 단계, 이미지 1/2 2006-2011 Honda Civic Dome Light Replacement: 2 단계, 이미지 2/2
    • Use a spudger and insert it into the space between the dome light cover and edge.
    • Gently pry the cover off but be careful that you don't break any of the clips attaching the cover to the assembly.
  3. 2006-2011 Honda Civic Dome Light Replacement: 3 단계, 이미지 1/1
    • Evaluate if the bulb is just loose or if it has burned out and needs to be replaced.
    • In this case, you can see that the bulb has turned black from the inside, indicating it has shorted out. This bulb needs to be replaced.
  4. 2006-2011 Honda Civic Dome Light Replacement: 4 단계, 이미지 1/2 2006-2011 Honda Civic Dome Light Replacement: 4 단계, 이미지 2/2
    • Use the spudger to detach the bulb from one end of the socket.
    • Pull the bulb out of the socket with the end that is loose.
  5. 2006-2011 Honda Civic Dome Light Replacement: 5 단계, 이미지 1/1
    • Align the new bulb with the socket and push it back into place.
    • Ensure the bulb is connected to each end of the socket or it will not function.
  6. 2006-2011 Honda Civic Dome Light Replacement: 6 단계, 이미지 1/3 2006-2011 Honda Civic Dome Light Replacement: 6 단계, 이미지 2/3 2006-2011 Honda Civic Dome Light Replacement: 6 단계, 이미지 3/3
    • Before attaching the cover of the dome light, reconnect the car battery carefully and test the light to make sure it works.
    • Align the tabs on the dome light cover with the holes in the assembly and push the cover back into place.
  7. 2006-2011 Honda Civic Dome Light Replacement: 7 단계, 이미지 1/1
    • You should now have a functioning dome light.
결론
Hashim
회원 가입일: 10/17/22
145 평판
안내서 1개 작성함
York University, Team B-1, Allen Fall 2022 York University, Team B-1, Allen Fall 2022 회원
YORK-ALLEN-F22SBG1
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 83
전체 시간: 1,072
