소개
In this guide, we will replace the battery of a 2006-2011 Honda Civic key FOB. This is a fairly simple project that can be completed rather than potentially spending a minimum of $90 on a replacement.
필요한 것
Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
거의 끝나갑니다!
To reassemble your key FOB, follow these instructions in reverse order.
결론
다른 3명이 해당 안내서를 완성하였습니다.
