주요 콘텐츠로 건너뛰기
소개
In this guide, we will replace the battery of a 2006-2011 Honda Civic key FOB. This is a fairly simple project that can be completed rather than potentially spending a minimum of $90 on a replacement.
  1. Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
    • Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
  2. Gently lift the outer shell and remove it from the rest of the device.
    • Gently lift the outer shell and remove it from the rest of the device.
    • Be careful not to break the clip located at the hole for the key ring that holds the shell in place.
  3. Remove the inner shell from the outer shell by pushing the buttons to loosen the inner shell.
    • Remove the inner shell from the outer shell by pushing the buttons to loosen the inner shell.
  4. Unclasp the inner shell using the clips on the top and bottom.
    • Unclasp the inner shell using the clips on the top and bottom.
    • Careful as to not break the clips as it keeps moisture, dust, and dirt from entering the delicate electronics.
  5. Remove the battery inside of the inner shell of the key FOB.
    • Remove the battery inside of the inner shell of the key FOB.
    • If the battery is corroded, make sure to wear gloves due to battery acid.
    • Do not puncture the battery when removing the old one/placing a new one.
  6. Replace the old battery with a new one.
    • Replace the old battery with a new one.
결론
To reassemble your key FOB, follow these instructions in reverse order.
Erika Caushi
회원 가입일: 2021년 03월 22일
133 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G6, Riel Spring 2021 UMass Dartmouth, Team S1-G6, Riel Spring 2021 회원
UMASSD-RIEL-S21S1G6
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 33
7일 전: 193
30일 전: 847
전체 시간: 2,504
