주요 콘텐츠로 건너뛰기
2006-2008 Isuzu i-Series Wiper Motor Replacement
필요한 것
  1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nut Caps: 1 단계, 이미지 1/1
    • Use a plastic prying tool or spudger to gently remove nut cap from wiper base.
  2. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: 2 단계, 이미지 1/3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: 2 단계, 이미지 2/3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: 2 단계, 이미지 3/3
    • Use a 5/8 wrench or socket to remove the necessary nut holding the wiper in place.
  3. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: 3 단계, 이미지 1/2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: 3 단계, 이미지 2/2
    • Once the necessary nuts are removed, the wiper blade itself can be removed.
    • This can be done easiest by first flexing the wiper to the upright position, then gently pulling the wiper off of the screw.
  4. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: 4 단계, 이미지 1/2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: 4 단계, 이미지 2/2
    • Open the hood of the truck for easier access to the wiper cowl.
    • Using pliers, locate the six retainer clips on the plastic cowl and remove them by pulling straight up.
  5. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: 5 단계, 이미지 1/3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: 5 단계, 이미지 2/3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: 5 단계, 이미지 3/3
    • Position your hands underneath the wiper cowl and start to gently loosen the plastic from the windshield.
    • Pull straight towards the front of the truck to slide the wiper cowl over the screws that held the wiper blades, exposing the wiper components underneath.
    • The wiper cowl is flexible and can therefore be removed a little bit at a time. Take your time.
  6. 2006-2008 Isuzu i-Series Wiper Motor Replacement: 6 단계, 이미지 1/3 2006-2008 Isuzu i-Series Wiper Motor Replacement: 6 단계, 이미지 2/3 2006-2008 Isuzu i-Series Wiper Motor Replacement: 6 단계, 이미지 3/3
    • Locate the two screws on each side of the wiper assembly.
    • Use a 10mm socket or wrench and remove each screw.
  7. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: 7 단계, 이미지 1/3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: 7 단계, 이미지 2/3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: 7 단계, 이미지 3/3
    • Rotate assembly towards the windshield while starting to remove it from the truck.
    • Unplug the wiring harness located towards the driver's side of the truck.
    • The wire can then be fed through to remove the assembly the rest of the way.
  8. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: 8 단계, 이미지 1/2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: 8 단계, 이미지 2/2
    • Remove the connecting arm socket with a 1/2 inch wrench or socket (red circle).
    • Remove the three motor bolts with a 10mm wrench or socket (orange circles).
    • The wiper motor is now able to be replaced.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alex
회원 가입일: 10/08/14
211 평판
안내서 1개 작성함
USF Tampa, Team 1-9, Donnelly Fall 2014 USF Tampa, Team 1-9, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G9
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 31
전체 시간: 3,944
