주요 콘텐츠로 건너뛰기
2006 Chrysler 300 Sun Visor Replacement
필요한 것
  1. 2006 Chrysler 300 Sun Visor Replacement, Sun Visor: 1 단계, 이미지 1/1
    • Unscrew the 2 screws from the left side of the bracket.
  2. 2006 Chrysler 300 Sun Visor Replacement: 2 단계, 이미지 1/1
    • Unhook and move the visor for access to the 3rd screw.
    • Hold the visor. Do not let go of the visor. If you do, the weight of the visor might damage the attached wires.
    • Unscrew the 3rd Screw.
  3. 2006 Chrysler 300 Sun Visor Replacement: 3 단계, 이미지 1/2 2006 Chrysler 300 Sun Visor Replacement: 3 단계, 이미지 2/2
    • Lightly pull the wire so the connector is outside of the headliner.
  4. 2006 Chrysler 300 Sun Visor Replacement: 4 단계, 이미지 1/2 2006 Chrysler 300 Sun Visor Replacement: 4 단계, 이미지 2/2
    • Press and lightly pull the small tab to release the connecting wires.
  5. 2006 Chrysler 300 Sun Visor Replacement: 5 단계, 이미지 1/2 2006 Chrysler 300 Sun Visor Replacement: 5 단계, 이미지 2/2
    • Reconnect the new sun visor wire.
    • Pull down slightly on the headliner and tuck the wire back inside.
  6. 2006 Chrysler 300 Sun Visor Replacement: 6 단계, 이미지 1/1
    • Align the bracket holes and screw in the right side screw.
  7. 2006 Chrysler 300 Sun Visor Replacement: 7 단계, 이미지 1/1
    • Hang the visor on the hook for support.
    • Screw in the other 2 screws.
결론
The same steps apply to replace the passenger side sun visor.
Bonnie
회원 가입일: 10/06/22
145 평판
안내서 1개 작성함
University of North Texas, Team 2-6, Raign Fall 2022 University of North Texas, Team 2-6, Raign Fall 2022 회원
UNT-RAIGN-F22S2G6
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 31
전체 시간: 538
