주요 콘텐츠로 건너뛰기
2006 Ford F-150 Door Handle Cable Replacement
필요한 것
  1. 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: 1 단계, 이미지 1/3 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: 1 단계, 이미지 2/3 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: 1 단계, 이미지 3/3
    • Remove the plastic cover from the door handle using a 7.6 cm slotted screwdriver.
    • Insert the screwdriver into the small opening found at the top of the plastic cover.
    • Carefully tilt the screwdriver upward to remove the plastic cover.
  2. 2006 Ford F-150 Door Handle Cable Replacement: 2 단계, 이미지 1/3 2006 Ford F-150 Door Handle Cable Replacement: 2 단계, 이미지 2/3 2006 Ford F-150 Door Handle Cable Replacement: 2 단계, 이미지 3/3
    • Remove the two 6 mm hex screws using a 6mm socket.
    • Turn the screwdriver counter-clockwise to loosen and remove the screws.
    • Grab the door handle and remove it from its location.
  3. 2006 Ford F-150 Door Handle Cable Replacement: 3 단계, 이미지 1/3 2006 Ford F-150 Door Handle Cable Replacement: 3 단계, 이미지 2/3 2006 Ford F-150 Door Handle Cable Replacement: 3 단계, 이미지 3/3
    • Remove the top plastic cover by pulling outward to snap it out of its location.
    • There are not any screws to remove in this part.
  4. 2006 Ford F-150 Door Handle Cable Replacement: 4 단계, 이미지 1/2 2006 Ford F-150 Door Handle Cable Replacement: 4 단계, 이미지 2/2
    • Remove the other plastic cover by pulling outward to snap it out of its location.
  5. 2006 Ford F-150 Door Handle Cable Replacement: 5 단계, 이미지 1/3 2006 Ford F-150 Door Handle Cable Replacement: 5 단계, 이미지 2/3 2006 Ford F-150 Door Handle Cable Replacement: 5 단계, 이미지 3/3
    • Remove the three 6 mm hex screws off the main door cover using a 6 mm socket. There are two screws at the top and one at the bottom.
    • The panel itself should stay in place even after the screws have been removed.
    • The door panel is maintained in place by plastic hooks behind it.
  6. 2006 Ford F-150 Door Handle Cable Replacement: 6 단계, 이미지 1/3 2006 Ford F-150 Door Handle Cable Replacement: 6 단계, 이미지 2/3 2006 Ford F-150 Door Handle Cable Replacement: 6 단계, 이미지 3/3
    • Gently, but with a strong force, lift the door cover about an inch or two high. Then, carefully pull it outward.
    • Be careful not to damage the plastic hooks that are keeping the door in place.
  7. 2006 Ford F-150 Door Handle Cable Replacement: 7 단계, 이미지 1/3 2006 Ford F-150 Door Handle Cable Replacement: 7 단계, 이미지 2/3 2006 Ford F-150 Door Handle Cable Replacement: 7 단계, 이미지 3/3
    • Snap out the upper end of the cable out of its location.
    • The upper end of the cable has a shape of a little ball. The little ball is found by where the door handle was removed.
    • Using a plier, lift the cable high enough so that the little ball can come out through the round opening above it.
  8. 2006 Ford F-150 Door Handle Cable Replacement: 8 단계, 이미지 1/3 2006 Ford F-150 Door Handle Cable Replacement: 8 단계, 이미지 2/3 2006 Ford F-150 Door Handle Cable Replacement: 8 단계, 이미지 3/3
    • Remove the three T27 hex star screws using a tamper torx screw driver. The screws are found at the bottom of the door.
    • You may need a mechanic creeper to lay under the door.
    • Wear protective goggles if you lay down under the door to do this step.
  9. 2006 Ford F-150 Door Handle Cable Replacement: 9 단계, 이미지 1/3 2006 Ford F-150 Door Handle Cable Replacement: 9 단계, 이미지 2/3 2006 Ford F-150 Door Handle Cable Replacement: 9 단계, 이미지 3/3
    • Insert your hand inside the bottom of the door to retrieve the door latch.
  10. 2006 Ford F-150 Door Handle Cable Replacement: 10 단계, 이미지 1/1
    • Remove the end of the cable out of its location.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Francisco Garcia
회원 가입일: 01/22/17
164 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 회원
USFSM-STEWART-S17S1G1
19 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 44
전체 시간: 1,996
