주요 콘텐츠로 건너뛰기
2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement
필요한 것
  1. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement, Throttle Position Sensor (TPS): 1 단계, 이미지 1/2 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement, Throttle Position Sensor (TPS): 1 단계, 이미지 2/2
    • Pull the release lever for the hood.
  2. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 2 단계, 이미지 1/1
    • Slide the latch under the center of the hood to the left and then open the hood.
  3. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 3 단계, 이미지 1/1
    • Disconnect the positive battery terminal by loosening the 10 mm nut and pulling the wire of the red battery terminal.
  4. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 4 단계, 이미지 1/3 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 4 단계, 이미지 2/3 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 4 단계, 이미지 3/3
    • Remove the connector attached to the TPS by sliding back the red clip and pulling.
  5. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 5 단계, 이미지 1/1
    • Use a T20 Torx screwdriver to remove the two bolts holding in the sensor.
  6. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 6 단계, 이미지 1/2 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 6 단계, 이미지 2/2
    • Remove the old TPS.
  7. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 7 단계, 이미지 1/1
    • Install the new TPS and put the two T20 Torx bolts back in.
  8. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 8 단계, 이미지 1/1
    • Connect the connector to the new TPS and make sure the red clip is pushed forward.
  9. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 9 단계, 이미지 1/1
    • Reconnect the positive battery terminal, by tightening the 10 mm nut and putting the red cover back over it.
  10. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 10 단계, 이미지 1/1
    • Close the hood and make sure it is closed securely.
  11. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 11 단계, 이미지 1/1
    • Start the car and make sure that it is running normally.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Nathaniel Johnson
회원 가입일: 03/16/21
220 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 65
전체 시간: 3,236
