소개
This guide will explain how to replace a failing throttle position sensor or TPS in a 2006 Ford Mustang with the 4.0L V6 motor. You may need to complete this repair if you have a rough idle or if the car is hesitating while accelerating. Your car may also display a check engine light. You can have an auto parts store or mechanic read the check engine code to confirm that this is in fact the issue you are having.
필요한 것
거의 끝나갑니다!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
