주요 콘텐츠로 건너뛰기
2006 Iron Horse Warrior Chainring Replacement
필요한 것
  1. 2006 Iron Horse Warrior Chainring Replacement, Chainring: 1 단계, 이미지 1/1
    • Remove the cap covering the crank arm using the 6mm Allen Key
  2. 2006 Iron Horse Warrior Chainring Replacement: 2 단계, 이미지 1/2 2006 Iron Horse Warrior Chainring Replacement: 2 단계, 이미지 2/2
    • Screw the larger diameter threads on the crank puller into the hole you removed the cap from.
    • Slightly tighten it with an adjustable wrench.
  3. 2006 Iron Horse Warrior Chainring Replacement: 3 단계, 이미지 1/3 2006 Iron Horse Warrior Chainring Replacement: 3 단계, 이미지 2/3 2006 Iron Horse Warrior Chainring Replacement: 3 단계, 이미지 3/3
    • Tighten the handle on the crank puller until the arm and gears slide off of the axle.
    • The crank puller works by locking into the threads on the arm and pushing against the Isis drive axle to pry the arm and gears off. Make sure you are using the correct size crank puller, otherwise this step will not work.
    • During reassembly, add some grease to the axle to make it easier to remove the arm in the future.
  4. 2006 Iron Horse Warrior Chainring Replacement: 4 단계, 이미지 1/3 2006 Iron Horse Warrior Chainring Replacement: 4 단계, 이미지 2/3 2006 Iron Horse Warrior Chainring Replacement: 4 단계, 이미지 3/3
    • Remove the four 6mm hex bolts from the small chainring using the 6mm hex screwdriver. This will allow you to remove the chainring.
    • When reinstalling, apply a loctite thread compound on the threads to keep them from loosening as you ride. Also, make sure the writing on the new chainring faces the frame of the bike.
    • This chainring has a bolt circle diameter of 64 mm (BCD 64) and 22 teeth; however, you can replace it with any chainring with a BCD of 64.
결론
Scott Kaufman
회원 가입일: 04/20/15
619 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 801
