주요 콘텐츠로 건너뛰기
2006 Iron Horse Warrior Rear Wheel Replacement
  1. 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: 1 단계, 이미지 1/2 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: 1 단계, 이미지 2/2
    • Turn the bike upside down if you don't have a bike stand. This will make it easier to remove the tire.
    • Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
  2. 2006 Iron Horse Warrior Rear Wheel Replacement: 2 단계, 이미지 1/2 2006 Iron Horse Warrior Rear Wheel Replacement: 2 단계, 이미지 2/2
    • On the right side, use your hands to unscrew the cap of the axle counterclockwise until it is loose.
  3. 2006 Iron Horse Warrior Rear Wheel Replacement: 3 단계, 이미지 1/2 2006 Iron Horse Warrior Rear Wheel Replacement: 3 단계, 이미지 2/2
    • Push down on the the tire with your hands to remove it from the frame of the bike.
    • Sometimes the axle will get caught in the boxed area. Use both of your hands to cautiously push it down harder until the tire comes loose. This may require a fair amount of force.
결론
Matt Halvorson
회원 가입일: 04/21/15
354 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,037
