주요 콘텐츠로 건너뛰기
2006 Iron Horse Warrior Tire/Tube Replacement
필요한 것
  1. 2006 Iron Horse Warrior Tire/Tube Replacement, Rear Wheel: 1 단계, 이미지 1/2 2006 Iron Horse Warrior Tire/Tube Replacement, Rear Wheel: 1 단계, 이미지 2/2
    • Turn the bike upside down if you don't have a bike stand. This will make it easier to remove the tire.
    • Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
  2. 2006 Iron Horse Warrior Tire/Tube Replacement: 2 단계, 이미지 1/2 2006 Iron Horse Warrior Tire/Tube Replacement: 2 단계, 이미지 2/2
    • On the right side, use your hands to unscrew the cap of the axle counterclockwise until it is loose.
  3. 2006 Iron Horse Warrior Tire/Tube Replacement: 3 단계, 이미지 1/2 2006 Iron Horse Warrior Tire/Tube Replacement: 3 단계, 이미지 2/2
    • Push down on the the tire with your hands to remove it from the frame of the bike.
    • Sometimes the axle will get caught in the boxed area. Use both of your hands to cautiously push it down harder until the tire comes loose. This may require a fair amount of force.
  4. 2006 Iron Horse Warrior Tire/Tube Replacement, Tire/Tube: 4 단계, 이미지 1/3 2006 Iron Horse Warrior Tire/Tube Replacement, Tire/Tube: 4 단계, 이미지 2/3 2006 Iron Horse Warrior Tire/Tube Replacement, Tire/Tube: 4 단계, 이미지 3/3
    • Slightly loosen the valve bolt counterclockwise with your thumb and index finger.
    • Deflate the tire by pressing down the air valve tip with your finger. Use as much pressure as needed to hear the air flowing out of the tube.
  5. 2006 Iron Horse Warrior Tire/Tube Replacement: 5 단계, 이미지 1/3 2006 Iron Horse Warrior Tire/Tube Replacement: 5 단계, 이미지 2/3 2006 Iron Horse Warrior Tire/Tube Replacement: 5 단계, 이미지 3/3
    • Use you thumb and index finger to unscrew the valve nut by rotating it counterclockwise.
  6. 2006 Iron Horse Warrior Tire/Tube Replacement: 6 단계, 이미지 1/3 2006 Iron Horse Warrior Tire/Tube Replacement: 6 단계, 이미지 2/3 2006 Iron Horse Warrior Tire/Tube Replacement: 6 단계, 이미지 3/3
    • Hold the tire lever firmly in your hands and look for the boundary between the tire and the wheel rim. Apply great force to the lever until you pry the rim and the tire apart.
    • You can do this step anywhere along the circumference of the wheel.
    • With the tip of the lever inserted between the rim and the tire, rotate the lever 90° counterclockwise and fix the lever to the metal spokes using the arrow shaped slot located on the top of the lever.
  7. 2006 Iron Horse Warrior Tire/Tube Replacement: 7 단계, 이미지 1/2 2006 Iron Horse Warrior Tire/Tube Replacement: 7 단계, 이미지 2/2
    • Insert an extra tire lever between the tire and the rim.
    • Move the lever along the circumference of the rim to pry the tire apart.
    • You may attach as many tire levers on the spokes as you feel necessary to make this step easier.
  8. 2006 Iron Horse Warrior Tire/Tube Replacement: 8 단계, 이미지 1/3 2006 Iron Horse Warrior Tire/Tube Replacement: 8 단계, 이미지 2/3 2006 Iron Horse Warrior Tire/Tube Replacement: 8 단계, 이미지 3/3
    • Start removing the tire by unplugging the valve from the rim slot.
    • Remove the rest of the tire and the tube from the rim.
결론
Once you have completed this guide, assemble the wheel back on the bike.
Jose Pedro Kitajima Borges
회원 가입일: 04/21/15
254 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 25
전체 시간: 2,008
