소개
This guide puts the bike on a stand to replace its tube. However, you can turn the bike upside down and follow the same steps if you do not have a stand.
필요한 것
Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
Slightly loosen the valve bolt counterclockwise with your thumb and index finger.
Deflate the tire by pressing down the air valve tip with your finger. Use as much pressure as needed to hear the air flowing out of the tube.
Hold the tire lever firmly in your hands and look for the boundary between the tire and the wheel rim. Apply great force to the lever until you pry the rim and the tire apart.
With the tip of the lever inserted between the rim and the tire, rotate the lever 90° counterclockwise and fix the lever to the metal spokes using the arrow shaped slot located on the top of the lever.
다른 한 분이 해당 안내서를 완성하였습니다.
