주요 콘텐츠로 건너뛰기
2006 Kia Spectra Battery Replacement
필요한 것
  1. 2006 Kia Spectra Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the car off.
  2. 2006 Kia Spectra Battery Replacement: 2 단계, 이미지 1/2 2006 Kia Spectra Battery Replacement: 2 단계, 이미지 2/2
    • Locate the hood release lever near the lower left side of the steering wheel. Pop the hood by lifting up on the release lever.
  3. 2006 Kia Spectra Battery Replacement: 3 단계, 이미지 1/3 2006 Kia Spectra Battery Replacement: 3 단계, 이미지 2/3 2006 Kia Spectra Battery Replacement: 3 단계, 이미지 3/3
    • Remove the positive (red circle) cable from the battery using the wrench to loosen the nut and bolt.
    • Then, remove the negative (orange circle) cable battery, using the wrench to loosen the nut and bolt.
  4. 2006 Kia Spectra Battery Replacement: 4 단계, 이미지 1/2 2006 Kia Spectra Battery Replacement: 4 단계, 이미지 2/2
    • Take the battery out, lifting the battery.
    • The battery will be heavy.
  5. 2006 Kia Spectra Battery Replacement: 5 단계, 이미지 1/1
    • Clean the new battery with a rag to make sure it is ready to go.
  6. 2006 Kia Spectra Battery Replacement: 6 단계, 이미지 1/3 2006 Kia Spectra Battery Replacement: 6 단계, 이미지 2/3 2006 Kia Spectra Battery Replacement: 6 단계, 이미지 3/3
    • Place the new battery in the base where the battery goes.
  7. 2006 Kia Spectra Battery Replacement: 7 단계, 이미지 1/2 2006 Kia Spectra Battery Replacement: 7 단계, 이미지 2/2
    • Attach the positive (red cirlce) cable to the battery by screwing on the nut and bolt with the wrench.
  8. 2006 Kia Spectra Battery Replacement: 8 단계, 이미지 1/3 2006 Kia Spectra Battery Replacement: 8 단계, 이미지 2/3 2006 Kia Spectra Battery Replacement: 8 단계, 이미지 3/3
    • Then, attach the negative (red arrow) cable to the battery by screwing on the nut and bolt with the wench.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Abigail Cerrillo
회원 가입일: 01/29/18
217 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 55
전체 시간: 4,685
